FPGA|CPLD|ASICwilliam hill官网
于阔
9年用户 54经验值
擅长:电源/新能源 处理器/DSP 控制/MCU
CPLD读取光栅尺的值
我写了个程序读光栅尺的值,我用示波器测输出,没有电平输出,苦恼中,求大神帮帮忙,在线等。
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENtiTY Meas IS
    PORT(   MeasIn:         IN STD_LOGIC_VECTOR(1 DOWNTO 0);
            Clk:            IN STD_LOGIC;
--            Updown:         IN STD_LOGIC;
            Count:          OUT STD_LOGIC
END Meas;
ARCHITECTURE Rt1 OF Meas IS
CONSTANT Stata0:            STD_LOGIC_VECTOR:="00";
CONSTANT Stata1:            STD_LOGIC_VECTOR:="10";
CONSTANT Stata2:            STD_LOGIC_VECTOR:="11";
CONSTANT Stata3:            STD_LOGIC_VECTOR:="01";
SIGNAL Oldstata:            STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL Temp0:               STD_LOGIC;
SIGNAL Temp1:               STD_LOGIC;
SIGNAL Temp2:               STD_LOGIC;
BEGIN
    PROCESS
    BEGIN
        WAIT UNTIL Clk = '1';
        IF MeasIn = Stata0 THEN
            Oldstata <= MeasIn;
            Temp0 <= MeasIn(0) XOR MeasIn(1);
            Temp1 <= Oldstata(0) XOR Oldstata(1);
            Temp2 <= Temp0 XOR Temp1;
            IF Temp2 = '1' THEN
                Count <= '1';
            ELSIF Temp2 = '0' THEN
                Count <= '0';
            END IF;
        ELSIF MeasIn = Stata1 THEN
            Oldstata <= MeasIn;
            IF Temp2 = '1' THEN
                Count <= '1';
                Count <= '0';
            END IF;
        ELSIF MeasIn = Stata2 THEN
            Oldstata <= MeasIn;
            IF Temp2 = '1' THEN
                Count <= '1';
                Count <= '0';
            END IF;
        ELSIF MeasIn = Stata3 THEN
            Oldstata <= MeasIn;
            IF Temp2 = '1' THEN
                Count <= '1';
                Count <= '0';
            END IF;
        END IF;
    END PROCESS;
END Rt1;
已退回5积分
