Linuxwilliam hill官网
重力。
10年用户 20经验值
擅长:可编程逻辑
linux内核驱动ZLG7290芯片
我的想法很简单就是直接7290来一个中断我就用I2C读取他的键值,其他的啥子都不操作,先仿照写了一个中断的驱动,按键盘上的任何键都会进入中断,说明中断时对的!没问题!然后我就想在中断理用I2C读取键值,加上读取函数加上就开发板就重启了,我的I2C用的引脚和开发板上的时钟PCF8763的是一样的?是不是就不初始化I2C的引脚,只需要申请总线直接就可以用了,求大家指点!!!!!!!!!
#include
#include
#include
#include
#include
#include
#include
#include
#include
//#include
#include
#include
#include
//#include "gps.h"
#include
#include
#include
//中断头文件
#include
#include
#define DPRINTK(x...) printk("7290key_irq DEBUG:" x)
#define DRIVER_NAME "7290key_irq"
#define BUZZER_GPIO                        EXYNOS4_GPD0(0)
#define ZLG7290                0x71
#define zlg7290key_read()  i2c_smbus_read_byte(0x70)
static struct i2c_client*g_client;
static irqreturn_t eint22_interrupt(int irq,void *dev_id)
{        static int Flay;
        unsigned char res ;
        printk("receive a interrupt 22!n");
        printk("%s, %dn", __FUNCTION__, __LINE__);
                ndelay(20);
        if(gpio_get_value(EXYNOS4_GPX2(6)))
                return IRQ_HANDLED;
//        res = zlg7290key_read();
        int ret =0;
        int count=0;
        char data_buff[20];
        ret=i2c_master_send(g_client,ZLG7290,1);
        ret=i2c_master_recv(g_client,data_buff,count);
        //copy_to_user(buf,data_buff,count);
        printk("ZLG7290 KEY value :%d!n",data_buff[0]);
        return IRQ_HANDLED;
static int keyirq_probe(struct platform_device *pdev)
        int ret;
        char *banner = "7290key_irq Initializen";
        printk(banner);
        ret = gpio_request(EXYNOS4_GPX2(6), "EINT22");
        if (ret) {
                printk("%s: request GPIO %d for EINT22 failed, ret = %dn", DRIVER_NAME,
                        EXYNOS4_GPX2(6), ret);
                return ret;
        s3c_gpio_cfgpin(EXYNOS4_GPX2(6), S3C_GPIO_SFN(0xF));
    s3c_gpio_setpull(EXYNOS4_GPX2(6), S3C_GPIO_PULL_UP);
    gpio_free(EXYNOS4_GPX2(6));
        //注册中断
        ret=request_irq(IRQ_EINT(22),eint22_interrupt,IRQ_TYPE_EDGE_FALLING,"my_eint22",pdev);
        if(ret<0)
                printk("Request IRQ %d failed, %dn",IRQ_EINT(22),ret);
                goto exit;
        return 0;
exit:
    return ret;
static int keyirq_remove (struct platform_device *pdev)
        free_irq(IRQ_EINT(22),pdev);
        return 0;
static int keyirq_suspend (struct platform_device *pdev, pm_message_t state)
        DPRINTK("keyirq suspend:power off!n");
        return 0;
static int keyirq_resume (struct platform_device *pdev)
        DPRINTK("keyirq resume:power on!n");
        return 0;
static struct platform_driver keyirq_driver = {
        .probe = keyirq_probe,
        .remove = keyirq_remove,
        .suspend = keyirq_suspend,
        .resume = keyirq_resume,
        .driver = {
                .name = DRIVER_NAME,
                .owner = THIS_MODULE,
static __devinit int zlg7290_i2c_probe(struct i2c_client *client,
                                        const struct i2c_device_id *id)
        printk("ZLG7290 device is detectedn");
        g_client=client;
        return 0;
static __devexit int zlg7290_i2c_remove(struct i2c_client *client)
{//        snd_soc_unregister_codec(&client->dev);
        kfree(i2c_get_clientdata(client));
        return 0;
static const struct i2c_device_id zlg7290_id[] = {
        {"zlg7290-i2c", 0},
MODULE_DEVICE_TABLE(i2c, zlg7290_id);
static struct i2c_driver zlg7290_i2c_driver = {
        .driver = {
                   .name = "zlg7290-i2c",
        .probe = zlg7290_i2c_probe,
        .remove =  __devexit_p(zlg7290_i2c_remove),
        .id_table = zlg7290_id,
static void __exit keyirq_exit(void)
        platform_driver_unregister(&keyirq_driver);
        i2c_del_driver(&zlg7290_i2c_driver);
        printk("7290key driver remove n");
static int __init keyirq_init(void)
        int ret = 0;
//        #if defined(CONFIG_I2C) || defined(CONFIG_I2C_MODULE)
        i2c_add_driver(&zlg7290_i2c_driver);
        if (ret != 0) {
                printk(KERN_ERR "Failed to register zlg7290 I2C driver: %dn",
                       ret);
//        #endif
        return platform_driver_register(&keyirq_driver);
module_init(keyirq_init);
module_exit(keyirq_exit);
MODULE_LICENSE("Dual BSD/GPL");
MODULE_AUTHOR("zL/.");
回帖(2)
川楠
2017-10-30 19:02:42
顶一下~~~~~~~~~~~~~~
jinyi7016
2018-8-3 08:41:30
不同的IIC,是不同的设备,要建设备节点,不可像单片机上那么操作
