单片机/MCUwilliam hill官网
登录
贾益铭
8年用户
26经验值
擅长:嵌入式技术 接口/总线/驱动 RF/无线
私信
关注
lcd12864程序在keil中出现好多重新定义,尝试了很多办法都改不了,求助大家了
开启该帖子的消息推送
单片机
#ifndef __LCD12864_H
#define __LCD12864_H
#include
#include
//---重定义关键词---//
#ifndef uchar
#define uchar unsigned char
#endif
#ifndef uint
#define uint unsigned int
#endif
#ifndef data12864
#define data12864 P0
#endif
***it RS = P2^0;
***it RW = P2^1;
***it E = P2^2;
***it rst_12864 = P2^3;
unsigned char read12684_data(uchar address);//12864读数据
void busychk_12864(void);//12864,忙碌检查
void write12864_comand(uchar comand);//12864写命令
void write12864_data(uchar dat);//12864写数据
void ini
ti
al_12864(); //12864初始化
void clear_CGRAM12864();//清空CGRAM
void delay_12864(uint a);
void write12864_address(uchar x,uchar y);//地址设置 第x行 第y列
void ShowStringPos(uchar x, uchar y,uchar *s);//写英文字符串,一行写满自动换行
void ShowGBString(uchar x, uchar y, uchar *s);//显示多个汉字
uchar code wendu[] = {"温度: 66.6 ℃"};
uchar code shidu[] = {"湿度: 66.6 %"};
uchar code mima[] = {"请输密码"};
uchar code succeed[]={"密码输入正确"};
uchar code fail[]={"密码输入错误"};
uchar code kaiji[]={/*-- 调入了一幅图像:C:UsersAdministratorPictures无标题.bmp --*/
/*-- 宽度x高度=128x64 --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,
0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x00,
0x00,0x48,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x00,
0x0F,0xCF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xF3,0xE0,
0x06,0x01,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x40,
0x01,0x86,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x80,
0x00,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x00,
0x01,0x32,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x00,
0x01,0xCE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2D,0x00,
0x03,0x03,0x00,0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x73,0x80,
0x00,0x04,0x00,0x00,0x00,0x18,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x80,};
uchar code ren[]={/*-- 调入了一幅图像:C:UsersAdministratorPicturesuser9_16x16.bmp --*/
/*-- 宽度x高度=16x16 --*/
0x07,0xE0,0x0F,0xF0,0x1F,0xF8,0x18,0x38,0x18,0x38,0x1C,0x78,0x1F,0xF8,0x0F,0xF0,
0x07,0xE0,0x0F,0xF0,0x14,0x38,0x13,0xF8,0x10,0x78,0x10,0x78,0x10,0x78,0x0F,0xF0}
#endif
#include "lcd12864.h"
void busychk_12864(void) //忙碌检测
uchar busytemp = 0x80;
E = 0;
RW = 1;
RS = 0;
E = 1;
while((busytemp & data12864));
E = 0;
Build target 'Target 1'
compiling iMAIN.c...
DHT11.H(16): error C141: syntax error near 'void'
iMAIN.c(80): warning C316: unterminated conditionals
compiling LCD12864.c...
LCD12864.C(2): error C141: syntax error near 'void'
LCD12864.C(3): error C231: 'busychk_12864': redefinition
LCD12864.C(3): error C141: syntax error near '{'
LCD12864.C(5): error C231: 'E': redefinition
LCD12864.C(6): error C231: 'RW': redefinition
LCD12864.C(7): error C231: 'RS': redefinition
LCD12864.C(8): error C279: 'E': multiple initialization
LCD12864.C(8): error C231: 'E': redefinition
LCD12864.C(9): error C141: syntax error near 'while'
LCD12864.C(9): error C141: syntax error near '&', expected ')'
LCD12864.C(9): error C129: missing ';' before ')'
Target not created
不是所有程序,第一段是头文件,第二段是lcd12864程序的第一个子程序,在这个子程序开始就报错了
已退回
5
积分
人中狼
2017-5-4 18:31:33
对头文件不熟,是不是跨文件调用没有加extern
贾益铭
2017-5-4 19:04:42
引用:
尝试过了,还是不行啊
引用:
尝试过了,还是不行啊
人中狼
2017-5-4 19:25:14
while((busytemp & data12864));多了一对括号
人中狼
2017-5-4 22:06:48
redefinition的错误是你在多个文件里定义了同样的一个名称,查查所有的程序和头文件吧
h1654155354.2334
2021-4-8 22:15:17
可能是同时包含了reg51和reg52
可能是同时包含了reg51和reg52
rotate(-90deg);
回复
相关问答
单片机
打开范例时候
出现
An error occured-The NI System Web Server is not running
2014-07-21
5259
求助
,STM32与
LCD12864
的串口显示。
2018-04-04
3711
LCD12864
仿真
2016-05-04
5318
LCD12864
画点问题
2014-03-29
4166
怎么实现基于
LCD12864
显示器的数字示波器设计
2021-05-10
1871
stm32
LCD12864
串口无显示
2018-04-03
6518
求助
大家
有木有
LCD12864
的讲解视频
2015-04-27
5651
LCD12864
的睡眠模式的的
程序
2018-04-22
2268
lcd12864
怎么用
2013-03-19
4571
LCD12864
显示
2016-09-01
4494
登录/注册
20万+
工程师都在用,
免费
PCB检查工具
无需安装、支持浏览器和手机在线查看、实时共享
查看
点击登录
登录更多精彩功能!
英国威廉希尔公司网站
william hill官网 版块
小组
免费开发板试用
ebook
直播
搜索
登录
