单片机/MCUwilliam hill官网
a1151729
8年用户 5经验值
擅长:可编程逻辑
51单片机E2PROM读写问题
   I2C 总线上,PCF8591 可以直接在1602上显示, 数据变化正常,但是PCF8591接入E2PROM后,读取出来的数据一直都是0XFF,哪位大神帮忙看看什么原因?
#include
#include "i2c.h"
#define  DATA P0
***it rs=P1^3;
***it rw=P1^4;
***it en=P1^5;
u8 lcd1602[5];
void write_1602com(u8 com)
     rs=0;
         rw=0;
         en=0;
         en=1;
         DATA=com;
         delay(5);
         en=0;
void write_1602dat(u8 dat)
     rs=1;
         rw=0;
         en=0;
         en=1;
         DATA=dat;
         delay(5);
         en=0;
void init()
      write_1602com(0x02);
          write_1602com(0x06);
          write_1602com(0x0c);
          write_1602com(0x38);
          write_1602com(0x01);
void display(u8 dat)
         u16 t;
                 t=dat*(50000.0/255)*2;                                 //        不知道为什么要乘上2,不然最大值只有一半
                 lcd1602[4]=t/10000;
         lcd1602[3]=(t-lcd1602[4]*10000)/1000;
         lcd1602[2]=(t-lcd1602[4]*10000-lcd1602[3]*1000)/100;
         lcd1602[1]=(t-lcd1602[4]*10000-lcd1602[3]*1000-lcd1602[2]*100)/10;
         lcd1602[0]=t%10;
             write_1602com(0x83);
             write_1602dat(lcd1602[4]+'0');
                 delay(2);
                 write_1602com(0x84);
             write_1602dat(lcd1602[3]+'0');
                    delay(2);
                 write_1602com(0x85);
             write_1602dat(lcd1602[2]+'0');
                    delay(2);
                 write_1602com(0x86);
             write_1602dat(lcd1602[1]+'0');
                    delay(2);
                 write_1602com(0x87);
             write_1602dat(lcd1602[0]+'0');
                    delay(2);
u8 read_PCF8591()
        u8 fun;
                start_i2c();
                write_i2c(0x90);
             i2c_wait_ack();
                 // return 1;
                write_i2c(0x00);
                i2c_wait_ack();
                  //return 1;
                start_i2c();
                write_i2c(0x91);
                i2c_wait_ack();
                  //return 1;
                fun=read_i2c();
                ack_i2c(0);
                stop_i2c();
                return fun;
void main()
         init();
         while(1)
           write_i2c_address( 532 ,read_PCF8591());
                display(read_i2c_address( 532 ));
          //        display(read_PCF8591());
                //delay(1000);
#include "i2c.h"
void delay(u8 n)
   u8 x,y;
   for(x=n;x>0;x--)
     for(y=110;y>0;y--);
void nops()                  //5ns延时
  do{_nop_();_nop_();_nop_();_nop_();_nop_();} while(0);
void start_i2c()
           sda=1;
        nops();
        scl=1;
        nops();
        sda=0;
        nops();
void stop_i2c()
    sda=0;
        nops();
        scl=1;
        nops();
        sda=1;
        nops();
void ack_i2c(bit ck)
    if(ck)
           sda=0;
        else
           sda=1;
        nops();
        scl=1;
        nops();
        scl=0;
        nops();
        sda=1;
        nops();
void i2c_wait_ack()
         u8 i;
         scl=1;
         nops();
         while((sda==1)&&(i<250)) i++;
         scl=0;
         nops();
void write_i2c(u8 dat)
    u8 i;
        for(i=0;i<8;i++)
             scl=0;
                 nops();
             if(dat&0x80)
                  sda=1;
                 else
                  sda=0;
                  nops();
                  scl=1;
                  dat<<=1;
                  nops();
u8 read_i2c()
         u8 i,temp=0;
         scl=0;
         nops();
         sda=1;
         nops();
         for(i=0;i<8;i++)
           temp=temp<<1;
           scl=1;
           nops();
           temp=temp|sda;
           scl=0;
           nops();
          return (temp);
void write_i2c_address(u8 add,u8 dat_byte)
    start_i2c();
    write_i2c(0xa2);
        i2c_wait_ack();
        write_i2c(add/256);
        i2c_wait_ack();
        write_i2c(add%256);
        i2c_wait_ack();
        write_i2c(dat_byte);
        i2c_wait_ack();
        stop_i2c();
        delay(5000);
u8 read_i2c_address(u8 read_add)
    u8 read_byte=0;
    start_i2c();
        write_i2c(0xa2);
    i2c_wait_ack();
    write_i2c(read_add/256);
        i2c_wait_ack();
        write_i2c(read_add%256);
        i2c_wait_ack();
        start_i2c();
        write_i2c(0xa3);
    i2c_wait_ack();
        read_byte=read_i2c();
//        ack_i2c(0);
        stop_i2c();
        return read_byte;
回帖(1)
a1151729
2018-1-8 17:39:37
引用: iczoom188 发表于 2018-1-8 16:14
STC很多系列的单片机片内都集成了EEPROM存储器(其实是Data Flash),方便用户使用,想得真周到!今天拍明芯城专业写了个小程序,测试了一下,工作正常。下面就上我自己写的源程序。本人在STC89C52RC单片机上试验成功。
用串口看看,也可以先把num1写入,再接着读出来然后显示看看是不是之前的数据,确保数据被正确写入
楼 ...
我外接的E2PROM at24c512  add之前是用的uint型的,后面找错误的时候改成uchar ,忘了改回来!串口接收回来的数据也不对。我感觉应该是read_i2c函数有问题!
