标准规范
电子工程师
21年用户 16604经验值
擅长:可编程逻辑 模拟技术 测量仪表 控制/MCU RF/无线 MEMS/传感技术
rs422 rs485标准
Unbalanced Line Drivers
Each signal that transmits in an RS-232 unbalanced data transmission
system appears on the interface connector as a voltage with reference to a
signal ground. For example, the transmitted data (TD) from a DTE device
appears on pin 2 with respect to pin 7 (signal ground) on a DB-25 connector.
This voltage will be negative if the line is idle and alternate between that
negative level and a positive level when data is sent with a magnitude of ±5 to
±15 volts. The RS-232 receiver typically operates within the voltage range of
+3 to +12 and -3 to
-12 volts as shown in Figure 1.1.
Balanced Line Drivers
In a balanced differential system the voltage produced by the driver
appears across a pair of signal lines that transmit only one signal. Figure 1.2
shows a schematic symbol for a balanced line driver and the voltages that
exist. A balanced line driver will produce a voltage from 2 to 6 volts across
its A and B output terminals and will have a signal ground (C) connection.
Although proper connection to the signal ground is important, it isn't used by
a balanced line receiver in determining the logic state of the data line. A
balanced line driver can also have an input signal called an “Enable” signal.
The purpose of this signal is to connect the driver to its output terminals, A
and B. If the “Enable” signal is OFF, one can consider the driver as
disconnected from the transmission line. An RS-485 driver must have the
“Enable” control signal. An RS-422 driver may have this signal, but it is not
always required. The disconnected or "disabled" condition of the line driver
usually is referred to as the “tristate1” condition of the driver.
附件: 您需要登录才可以下载或查看附件。没有帐号?注册
回帖(1)
feng20101
2008-7-1 11:37:46
感谢楼主 分享
