扫一扫,分享给好友
am3352使用port1连接marvell6095,使用mii模式。管脚配置如下:
static struct pinmux_config mii1_pin_mux[] = [ ["mii1_rxerr.mii1_rxerr", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLDOWN], ["mii1_txen.mii1_txen", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT], ["mii1_rxdv.mii1_rxdv", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLDOWN], ["mii1_txd3.mii1_txd3", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT], ["mii1_txd2.mii1_txd2", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT], ["mii1_txd1.mii1_txd1", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT], ["mii1_txd0.mii1_txd0", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT], ["mii1_txclk.mii1_txclk", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLDOWN], ["mii1_rxclk.mii1_rxclk", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLDOWN], ["mii1_rxd3.mii1_rxd3", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLDOWN], ["mii1_rxd2.mii1_rxd2", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLDOWN], ["mii1_rxd1.mii1_rxd1", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLDOWN], ["mii1_rxd0.mii1_rxd0", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLDOWN], ["mdio_data.mdio_data", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP], ["mdio_clk.mdio_clk", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT_PULLUP], [NULL, 0], ]; 设置网卡工作模式: static void setup_cm335x(void) [ /* DEVKIT8600 has Micro-SD slot which doesn't have Write Protect pin */ am335x_mmc[0].gpio_wp = -EINVAL; _configure_device(EVM_SK, cm335x_dev_cfg, PROFILE_NONE); am33xx_cpsw_init(AM33XX_CPSW_MODE_MII, NULL, NULL); ] mdio可以扫描到所有phy,mii时钟测试是25mhz。其他地方没有修改,但是ping不通。原始代码是使用rgmii和ar8035网络是通的,rgmii的管脚配置如下: static struct pinmux_config rgmii1_pin_mux[] = [ ["mii1_txen.rgmii1_tctl", OMAP_MUX_MODE2 | AM33XX_PIN_OUTPUT], ["mii1_rxdv.rgmii1_rctl", OMAP_MUX_MODE2 | AM33XX_PIN_INPUT_PULLDOWN], ["mii1_txd3.rgmii1_td3", OMAP_MUX_MODE2 | AM33XX_PIN_OUTPUT], ["mii1_txd2.rgmii1_td2", OMAP_MUX_MODE2 | AM33XX_PIN_OUTPUT], ["mii1_txd1.rgmii1_td1", OMAP_MUX_MODE2 | AM33XX_PIN_OUTPUT], ["mii1_txd0.rgmii1_td0", OMAP_MUX_MODE2 | AM33XX_PIN_OUTPUT], ["mii1_txclk.rgmii1_tclk", OMAP_MUX_MODE2 | AM33XX_PIN_OUTPUT], ["mii1_rxclk.rgmii1_rclk", OMAP_MUX_MODE2 | AM33XX_PIN_INPUT_PULLDOWN], ["mii1_rxd3.rgmii1_rd3", OMAP_MUX_MODE2 | AM33XX_PIN_INPUT_PULLDOWN], ["mii1_rxd2.rgmii1_rd2", OMAP_MUX_MODE2 | AM33XX_PIN_INPUT_PULLDOWN], ["mii1_rxd1.rgmii1_rd1", OMAP_MUX_MODE2 | AM33XX_PIN_INPUT_PULLDOWN], ["mii1_rxd0.rgmii1_rd0", OMAP_MUX_MODE2 | AM33XX_PIN_INPUT_PULLDOWN], ["mdio_data.mdio_data", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP], ["mdio_clk.mdio_clk", OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT_PULLUP], [NULL, 0], ]; 请问我这样修改为mii为什么网络会不通? 请帮忙分析下,谢谢 |
7个回答
在linux user space下,用的devmem2打印上面的pinmux相应寄存器和gmii_sel寄存器,确认配置生效了吗?还有PHY_ID设置对了吗?
hwjj940056201 发表于 2018-5-15 09:16 gmii_sel: root@cm335x:~# devmem 0x44e10650 0x00000000 gmii_sel = 0x00000000 管脚配置: root@cm335x:~# devmem 0x44e10908 0x00000027 root@cm335x:~# devmem 0x44e1090c 0x00000036 root@cm335x:~# devmem 0x44e10910 0x00000020 root@cm335x:~# devmem 0x44e10914 0x00000000 root@cm335x:~# devmem 0x44e10918 0x00000020 root@cm335x:~# devmem 0x44e1091c 0x00000000 root@cm335x:~# devmem 0x44e10920 0x00000000 root@cm335x:~# devmem 0x44e10924 0x00000000 root@cm335x:~# devmem 0x44e10928 0x00000000 root@cm335x:~# devmem 0x44e1092c 0x00000020 root@cm335x:~# devmem 0x44e10930 0x00000020 root@cm335x:~# devmem 0x44e10934 0x00000020 root@cm335x:~# devmem 0x44e10938 0x00000020 root@cm335x:~# devmem 0x44e1093c 0x00000020 root@cm335x:~# devmem 0x44e10940 0x00000020 root@cm335x:~# devmem 0x44e10944 0x00000027 root@cm335x:~# devmem 0x44e10948 0x00000030 root@cm335x:~# devmem 0x44e1094c 0x00000010 conf_mii1_col = 0x27 conf_mii1_crs = 0x36 conf_mii1_rx_er = 0x20 conf_mii1_tx_en = 0x0 conf_mii1_rx_dv = 0x20 conf_mii1_txd3 = 0x0 conf_mii1_txd2 = 0x0 conf_mii1_txd1 = 0x0 conf_mii1_txd0 = 0x0 conf_mii1_tx_clk = 0x20 conf_mii1_rx_clk = 0x20 conf_mii1_rxd3 = 0x20 conf_mii1_rxd2 = 0x20 conf_mii1_rxd1 = 0x20 conf_mii1_rxd0 = 0x20 conf_mdio = 0x30 conf_mdc = 0x10 phyid配置是正确的,可以正确读到id,我双向互相ping,我示波器看信号,看不到tx_en,rx和tx都没有信号 麻烦看下是否有问题?谢谢 |
如果是没有信号,要仔细检查下pinmux |
除了col和crs管脚,我对过手册配置应该都是正确的(具体值在上面的打印中),参考设计里,col和crs都是不配置的,我把这两个信号直接接地了 |
fionacyl 发表于 2018-5-15 09:53 mii需要格外配置时钟吗? |
你好,请问你调通了么?我现在也是改成mii模式,文件系统中ifconfig 网口的时候 能读到phy id ;net eth1: CPSW phy found : id is : 0x2430d80
但是没有ping通 |
2913个成员聚集在这个小组
加入小组371 浏览 1 评论
565 浏览 2 评论
813 浏览 3 评论
679 浏览 1 评论
1150 浏览 1 评论
114浏览 29评论
533浏览 23评论
280浏览 20评论
228浏览 14评论
89浏览 13评论
GMT+8, 2025-1-5 12:24 , Processed in 0.950827 second(s), Total 88, Slave 72 queries .
