在协议栈中,关闭自动期满功能,频繁改变节点的位置,路由表会不会满?如何删除已满的路由表? |
How to adjust the number of routing table entries and expiration of routing table entries.
The Routing Table can be dynamically sized by setting the MAX_RTG_ENTRIES compile option in f8wConfig.cfg. In addition Route Expiration can be setup by changing the ROUTE_EXPIRY_TIME option (value in seconds). If you set ROUTE_EXPIRY_TIME=0, route entries will never expire. However in this case if a new Routing Entry needs to be added it will replace an existing one when the table is full. |
2916个成员聚集在这个小组
加入小组402 浏览 0 评论
380 浏览 1 评论
574 浏览 2 评论
826 浏览 3 评论
687 浏览 1 评论
121浏览 29评论
617浏览 23评论
286浏览 20评论
237浏览 14评论
95浏览 13评论
GMT+8, 2025-1-8 12:12 , Processed in 0.822218 second(s), Total 77, Slave 61 queries .
