Loading from nand0, offset 0x800000
Image Name: Linux-2.6.32.17-davinci1
Created: 2017-03-21 4:58:01 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2198064 Bytes = 2.1 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux.............................................................................................................................................. done, booting the kernel.
Linux version 2.6.32.17-davinci1 (root@ubuntu) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #255 PREEMPT Tue Mar 21 12:57:53 CST 2017
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: DaVinci DM36x EVM
Memory policy: ECC disabled, Data cache writeback
DaVinci dm36x_rev1.2 variant 0x8
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 15240
Kernel command line: mem=60M console=ttyS0,115200n8 noinitrd root=/dev/nfs rw ip=192.168.1.100:192.168.1.10:192.168.1.1:255.255.255.0 nfsroot=192.168.1.10:/home/targetfs,nolock vpfe_capture.interface=0 davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=pal mac=00:33:66:88:00:00
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 60MB = 60MB total
Memory: 56140KB available (4112K code, 386K data, 140K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:245
Console: colour dummy device 80x30
Calibrating delay loop... 215.44 BogoMIPS (lpj=1077248)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
DaVinci: 8 gpio irqs
NET: Registered protocol family 16
davinci_serial_init:97: failed to get UART2 clock
---------dm365_init_spi1-----------
bio: create slab
at 0
DM365 IPIPE initialized in Continuous mode
SCSI subsystem initialized
u***core: registered new interface driver u***fs
u***core: registered new interface driver hub
u***core: registered new device driver u***
vpss vpss: dm365_vpss vpss probed
vpss vpss: dm365_vpss vpss probe success
dm365_afew_hw_init
ch0 default output "COMPOSITE", mode "PAL"
VPBE Encoder Initialized
cfg80211: Calling CRDA to update world regulatory domain
LogicPD encoder initialized
Switching to clocksource timer0_1
mu***_hdrc: version 6.0, cppi-dma, peripheral, debug=0
mu***_hdrc: USB Peripheral mode controller at fec64000 using DMA, IRQ 12
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 109
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered (default)
Console: switching to colour frame buffer device 90x36
davincifb davincifb.0: dm_osd0_fb: 720x576x16@0,0 with framebuffer size 810KB
davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 1224KB
davincifb davincifb.0: dm_osd1_fb: 720x576x4@0,0 with framebuffer size 810KB
davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 1224KB
DM365 IPIPEIF probed
imp serializer initialized
davinci_previewer initialized
davinci_resizer initialized
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
console [ttyS0] enabled
serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
brd: module loaded
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
2 NAND chips detected
Creating 6 MTD partitions on "davinci_nand.0":
0x000000000000-0x000000780000 : "bootloader"
0x000000780000-0x000000800000 : "params"
0x000000800000-0x000000c00000 : "kernel"
0x000000c00000-0x000002c00000 : "basefs"
0x000002c00000-0x000006c00000 : "userfs"
0x000006c00000-0x000008000000 : "userdata"
davinci_nand davinci_nand.0: controller rev. 2.3
spi_davinci spi_davinci.1: Controller at 0xfec66800
console [netcon0] enabled
netconsole: network logging started
Initializing USB Mass Storage driver...
u***core: registered new interface driver u***-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
Linux video capture interface: v2.00
ths7303 1-002c: chip found @ 0x58 (DaVinci I2C adapter)
ths7303 1-002c: ths7303 write failed
ths7303: probe of 1-002c failed with error -121
vpfe_init
vpfe-capture: vpss clock vpss_master enabled
vpfe-capture vpfe-capture: v4l2 device registered
vpfe-capture vpfe-capture: video device registered
EVM: switch to tvp5150 SD video input
tvp5150:PINMUX4_OFFSET = 5555C555
tvp5150:PINMUX4_OFFSET = 5545C555
tvp5150 1-005d: chip found @ 0xba (DaVinci I2C adapter)
vpfe-capture vpfe-capture: v4l2 sub device tvp5150 registered
vpfe_register_ccdc_device: DM365 ISIF
DM365 ISIF is registered with vpfe.
af major#: 252, minor# 0
AF Driver initialized
aew major#: 251, minor# 0
AEW Driver initialized
Trying to register davinci display video device.
layer=c2533000,layer->video_dev=c2533170
layer=c2533400,layer->video_dev=c2533570
davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
watchdog watchdog: heartbeat 5 sec
davinci_mmc davinci_mmc.0: Using DMA, 4-bit mode
Advanced Linux Sound Architecture Driver Version 1.0.21.
asoc: CQ93VC <-> davinci-vcif mapping ok
ALSA device list:
#0: DaVinci DM365 EVM (CQ93VC)
TCP cubic registered
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
Clocks: disable unused mmcsd1
Clocks: disable unused spi0
Clocks: disable unused spi2
Clocks: disable unused spi3
Clocks: disable unused spi4
Clocks: disable unused pwm0
Clocks: disable unused pwm1
Clocks: disable unused pwm2
Clocks: disable unused pwm3
Clocks: disable unused timer1
Clocks: disable unused timer3
Clocks: disable unused adc
Clocks: disable unused emac
Clocks: disable unused asp0
Clocks: disable unused rto
Clocks: disable unused mjcp
emac-mii: probed
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa ACLCD 29.7 GiB
mmcblk0:
p1
eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, id=221513)
IP-Config: Complete:
device=eth0, addr=192.168.1.100, mask=255.255.255.0, gw=192.168.1.1,
host=192.168.1.100, domain=, nis-domain=(none),
bootserver=192.168.1.10, rootserver=192.168.1.10, rootpath=
Looking up port of RPC 100003/2 on 192.168.1.10
PHY: 1:01 - Link is Up - 100/Full
Looking up port of RPC 100005/1 on 192.168.1.10
VFS: Mounted root (nfs filesystem) on device 0:13.
Freeing init memory: 140K
---mount all---
---mdev setting---
local service
======Run application sctrip file=====
=====cd /dm368/=====
CMEMK module: built on Mar 24 2011 at 19:34:57
Reference Linux version 2.6.32
File /sdk/build/DVSDK_4_02/4_02_00_06/arago-install/arago-tmp/work/dm365-evm-none-linux-gnueabi/ti-linuxutils-1_2_26_01_02-r52d/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc8000000 of size 0x4400000
heap fallback enabled - will try heap if pool buffer is not available
CMEM Range Overlaps Kernel Physical - allowing overlap
CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83c00000)
cmemk initialized
IRQK module: built on Mar 24 2011 at 19:35:11
File /sdk/build/DVSDK_4_02/4_02_00_06/arago-install/arago-tmp/work/dm365-evm-none-linux-gnueabi/ti-linuxutils-1_2_26_01_02-r52d/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
irqk initialized
EDMAK module: built on Mar 24 2011 at 19:35:06
File /sdk/build/DVSDK_4_02/4_02_00_06/arago-install/arago-tmp/work/dm365-evm-none-linux-gnueabi/ti-linuxutils-1_2_26_01_02-r52d/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
g_file_storage gadget: File-backed Storage Gadget, version: 20 November 2008
g_file_storage gadget: Number of LUNs=1
g_file_storage gadget-lun0: ro=0, file: /dev/mmcblk0
是参考设计的,这个格式应该比较好看,还请您帮忙看一下问题在哪
OK
Starting kernel ...
NR_IRQS:245
bio: create slab
at 0
dm365_afew_hw_init
TCP reno registered
brd: module loaded
vpfe_init
ALSA device list:
emac-mii: probed
mmcblk0:
p1
---mount all---
---mdev setting---
local service
cmemk initialized
irqk initialized
