扫一扫,分享给好友
8168EVM,基于DVRRDK的Link编程,我想实现文件反复读取一帧YUV图像,送到VPSS然后经过display link从hdmi输出,相关的初始化已经好了,比如system_init(),现在卡在一个初始化分辨率的函数上
Int32 Chains_displayCtrlInit(UInt32 displayRes[]) [ Int32 status, i; VDIS_PARAMS_S prm; for (i = 0; i < SYSTEM_DC_MAX_VENC; i++) [ prm.deviceParams.resolution = displayRes; ] prm.deviceParams[SYSTEM_DC_VENC_HDMI].resolution = SYSTEM_STD_1080P_60; status = System_linkControl( SYSTEM_LINK_ID_M3VPSS, SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT, &prm, sizeof(prm), TRUE ); UTILS_assert(status==OSA_SOK); return status; ] 出错打印信息如下: setenv bootargs 'mem=256M console=ttyO2,115200n8 root=/dev/nfs rw nfsroot=192.168.1.3:/rfs_816x ip=192.168.1.2:192.168.1.3:192.168.1.1:255.255.255.0::eth0:off vram=20M notifyk.vpssm3_sva=0xBEE00000 ddr_mem=1024M' rom816x:/opt/dvrti816x# rom816x:/opt/dvrti816x/demo# .t begin to init!!!!!!!!!! 0: SYSTEM: System Commnit in progress !!! 0: SYSTEM: IPC init in progress !!! 12: SYSTEM: CPU [DSP] syslink proc ID is [0] !!! 12: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!! 12: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!! 12: SYSTEM: CPU [HOST] syslink proc ID is [3] !!! 12: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ... 14: SYSTEM: Creating MsgQ [HOST_MSGQ] ... 16: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ... 17: SYSTEM: Opening MsgQ [DSP_MSGQ] ... 18: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ... 18: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ... 19: SYSTEM: Notify register to [DSP] line 0, event 15 ... 20: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ... 20: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ... 21: SYSTEM: IPC init DONE !!! 22: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ... 24: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ... 25: SYSTEM: ListElem Shared Addr = 0x406c8680 26: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ... 28: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ... 29: SYSTEM: ListElem Shared Addr = 0x406ff480 31: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ... 33: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ... 34: SYSTEM: ListElem Shared Addr = 0x40736280 35: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ... 37: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ... 39: SYSTEM: ListElem Shared Addr = 0x40779580 40: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ... 42: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ... 43: SYSTEM: ListElem Shared Addr = 0x407bc880 59: SYSTEM: System Commnit Done !!! init is done!!!!!!!!! link setup is done!!!!!! [m3vpss ] 13700: Assertion @ Line: 314 in linkspsstem/systemrl.c: dctrlTriDisplayConfig != NULL : failed !!! 能否告诉我出错原因呢,我是仿照link demo来写的,谢谢 |
你好;
你这个错误是在初始化 display 模块的时候的问题; 报错应当是在DVRRDK_04.01.00.02/dvr_rdk/mcfw/src_bios6/links_m3vpss/system/system_dctrl.c (你上面的报错信息查不到,是不是打印有问问题,好像看不全) 你可以到这个里面来调试一下 这里可能是数据模式、通道绑定,状态以及一些display 的相关参数配置错了,或逻辑有问题导致的; 你可以贴出更多的信息,大家一起来分析; |
2930个成员聚集在这个小组
加入小组577 浏览 1 评论
414 浏览 1 评论
610 浏览 2 评论
884 浏览 3 评论
700 浏览 1 评论
169浏览 29评论
1135浏览 23评论
312浏览 20评论
270浏览 14评论
119浏览 13评论
GMT+8, 2025-1-28 15:51 , Processed in 0.891487 second(s), Total 75, Slave 59 queries .
