串口信息如下:
U-Boot SPL 2013.01.01 (Oct 25 2014 - 04:49:57)
mu***-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
mu***-hdrc: MHDRC RTL version 2.0
mu***-hdrc: setup fifo_mode 4
mu***-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
Using default environment
u***_ether
using mu***-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC c8:a0:30:c5:db:10
HOST MAC de:ad:be:af:00:00
RNDIS ready
mu***-hdrc: peripheral reset irq lost!
high speed config #2: 2 mA, Ethernet Gadget, using RNDIS
USB RNDIS network up!
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
Retry count exceeded; starting again
RNDIS ready
BOOTP broadcast 1
Using u***_ether device
TFTP from server 192.168.2.1; our IP address is 192.168.2.2
Filename 'u-boot-restore.img'.
Load address: 0x807fffc0
Loading: *#########################
877.9 KiB/s
done
Bytes transferred = 365104 (59230 hex)
U-Boot 2013.01.01 (Oct 25 2014 - 04:49:57)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - readenv() failed, using default environment
USB Host mode controller at 47401800 using PIO, IRQ 0
Net:
not set. Validating first E-fuse MAC
cpsw, u***_ether
Hit any key to stop autoboot: 0
RNDIS ready
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 192.168.2.2
RNDIS ready
ERROR: The remote end did not respond in time.
at ether.c:2395/u***_eth_init()
cpsw Waiting for PHY auto negotiation to complete......... TIMEOUT !
Using cpsw device
Filename 'uImage'.
Load address: 0x81000000
Loading: *cpsw Waiting for PHY auto negotiation to complete......... TIMEOUT !
T cpsw Waiting for PHY auto negotiation to complete......... TIMEOUT !
串口信息如下:
u***_ether
RNDIS ready
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
RNDIS ready
BOOTP broadcast 1
877.9 KiB/s
done
I2C: ready
DRAM: 512 MiB
0 MiB
Net:
cpsw, u***_ether
RNDIS ready
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
RNDIS ready
Using cpsw device
Filename 'uImage'.
