测试前的准备(preparation before test) 1)准备MY-RK3288-EK314开发板一套,5V直流稳压电源,USB转串口线。 prepare a set of MY-RK3288-EK314 development board, 5V DC power supply, USB to serial cable. 2)接上串口线,给开发板供电,启动板子。 connect the serial cable to the development board and power/span> 测试项目(test item) 网口测试(network inferface test)MY-RK3288-EK314 评估板支持双网口,一个百兆,另一个千兆。 MY-RK3288-EK314 support two ethernet interfaces, one is 100 Mbps ethernet, the other is 1 Gbps ethernet 接口属性(interface property)
测试方法(test method)1) 测试说明 test instruction
2) Eth0连接测试 Eth0 connect test
3) Eth1连接测试 Eth1 connect test
# ifconfig eth1 192.168.137.100 # configure the eth1 # ping -I eth1 192.168.137.1 # send ICMP to HOST
USB测试(USB test)接口属性(interface property)
测试方法(test method)1) 开始测试 start test 将USB设备插入底板USB接口,点击“ApkInstaller“->”Install“->”USB Memory“ insert USB device into USB port on base board,enter the following command: 2) 测试结束 test over 将USB设备从底板拔出 instruction:when plug in & out U disk from USB interface 附图(figure) SD卡测试(SD card test)接口属性(interface property)[/table][table=98%,transparent] 评估板型号 (evaluation model no.) 接口位置 (interface position) 接口类型 (interface type) MY-RK3288-EK314U22SD 开始测试(start test)1) 往SD卡槽插入设备 insert device into SD card slot 插入SD卡到底板SD卡接口,点击”ApkInstaller”->“Install”->“TF Card” insert SD card into SD card port on base board 2) 结束测试 test over SD卡弹出后拨出SD卡即结束测试。 take out SD card after SD card pop-pup,then test is over。 附图(figures) 背光测试(audio test)点击“Setting”->“Display”->“Brightness level” 附图(figures) 音频测试(audio test)测试说明(test instruction) 这项测试是通过播放音频文件验证评估板的音频功能。 the test is to verify audio function of evaluation board by playing audio file。 测试方法(test method) 1)准备测试 prepare test 连接音频输出设备到底板正面的音频座子,音频座子在底板正面“P15”。 connect audio output device to audio element in front view of base board,audio element is “J20”in front view of base board。 2)执行测试 execute test 用U盘准备mp3音频文件,插上U盘,直接打开mp3文件 附图(figures) 标准GPIO测试(standard GPIO test)接口属性(interface property)
测试方法(test method)1)GPIO输出测试 GPIO output test
# OUT_IO_NUMBER=9
# echo ${OUT_IO_NUMBER} > /sys/class/gpio/export
# echo out > /sys/class/gpio/gpio${OUT_IO_NUMBER}/direction
# echo 0 > /sys/class/gpio/gpio${OUT_IO_NUMBER}/value # echo 1 > /sys/class/gpio/gpio${OUT_IO_NUMBER}/value 2)GPIO输入测试 GPIO input test
# IN_IO_NUMBER=18
# echo ${IN_IO_NUMBER} > /sys/class/gpio/export
# echo in > /sys/class/gpio/gpio${IN_IO_NUMBER}/direction
cat /sys/class/gpio/gpio${IN_IO_NUMBER}/value GPIO-KEY测试(GPIO-KEY test)接口属性(interface property)
测试方法(test method)直接按SW1和SW2 press SW1 and SW2 附图(figures) 串口测试(serial port test)MY-RK3288-EK314共3个串口,其中1个调试串口,2个用户串口。 MY-RK3288-EK314 has total 5 serial ports,one is debug seiral port,the other 4 are user serial ports。 用户串口属性(user serial port property)
tips:transceiver pins of serial port are listed here,but please refer to schematic for definition of all pins of serial port。 串口测试(serial port test)
RTC测试(RTC test)测试说明(test instruction) 受快递运输影响,MY-RK3288-EK314 系列评估板发货时不带电池。测试RTC前请自备纽扣电池并安装到评估板上。 due to restrictions in transportation,MY-RK3288-EK314 evaluation board doesn't contatin battery in delivery。before RTC test please prepare button cell to install on evaluation board。 MY-RK3288-EK314的电池座在底板正面的“BT1”位置。 MY-RK3288-EK314 battery holder is located in“BT1”on front view of base board。 测试方法(test method ) 1)开机后查看"clock" power on, and look at the clock
2)关机后,等一会儿再开机: power off ,wait for a while and power on
SPI测试(SPI test)MY-RK3288-EK314上有两组SPI接口。 MY-RK3288-EK314 has two groups of SPI interfaces。 接口属性(interface property)测试需要用到SPI接口的MISO和MOSI管脚,在下表中列出。 pins of MISO and MOSI need to be used for test,listed as below。
adopt way of SPI self-sending(output)self-receiving(input)。 注意:测试需要短接评估板的管脚,如果不确定自己能正确短接的请找硬件工程师支持,否则可能会损坏评估板。 note:the test need a short connection of evaluation board pins,if you are not sure of how to conduct this kind of connection,please ask hardware engineer for a support,otherwise it may cause a damage of evaluation board。 2)与SPI测试程序匹配的SPI接口是SPI2,所以我们的SPI测试是测试SPI2。 SPI port which is matched up with SPI test program is SPI2,e.g.SPI test is SPI2 test。 测试方法(test method) 1)准备测试 prepare test 短接SPI0的MISO和MOSI管脚。 short connect MISO pin and MOSI pin of SPI2。 2)执行测试 execute test # ./spi_test -D /dev/spidev0.0 3)测试结果 test result 如果SPI正常,在终端上会看到如下字符: if SPI is normal,you can see following charaters on terminal: FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF DE AD BE EF BA AD F0 0D 附图(figures) 摄像头OV13850测试(camera ov13850 test)接上摄像头,启动,接着打开“Camera”,会出现如下:
WIFI测试(WIFI test)MY-RK3288-EK314 评估板使用的WIFI芯片型号为AP6335 the WIFI chip model used on the MY-RK3288-EK314 evaluation board is AP6335 1)步骤一 step one 点击“Settings”->“Wi-Fi”,打开WIFI的开关 click on “Settings”->“Wi-Fi”, turn on wifi 2)步骤二 step two 输入WIFI密码,并连接成功 enter WIFI password and connect successfully 蓝牙测试(Bluetooth test)MY-RK3288-EK314 评估板使用的Bluetooth芯片型号为AP6335 the Bluetooth chip model used on the MY-RK3288-EK314 evaluation board is AP6335 1)步骤一 step one 点击“Settings”->“Bluetooth”,打开蓝牙 click on “Settings”->“Bluetooth”,turn on Bluetooth 2)步骤二 step two 匹配 match 3)步骤三 step three 发送和接收文件 send and receive files 4G测试(4G internet module test)测试说明(test instruction)测试上网4G模块,如L506。 test online 4G module, such as L506. 测试方法(test method)
HDMI测试(HDMI test)测试说明(test instruction)接上HDMI显示屏。 Connect HDMI. 测试方法(test method)
用AndroidTool_Release_v2.35烧写。 Write the image with AndroidTool_Release_v2.35.
Power on, HDMI has display image
想修改分辨率,可以修改arch/arm/boot/dts/lcd-box.dtsi。 to modify the resolution, modify arch/arm/boot/dts/lcd-box.dtsi. EDP测试(EDP test)测试说明(test instruction)接上EDP显示屏。 Connect EDP. 测试方法(test method)
Power on, EDP has display image
想修改分辨率,可以修改arch/arm/boot/dts/lcd-EDP1080p.dtsi。 to modify the resolution, modify arch/arm/boot/dts/lcd-EDP1080p.dtsi. |
迅为RK3568开发板篇OpenHarmony配置HDF驱动控制LED-配置创建私有配置文件
1270 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-初识设备树之Makefile修改
1365 浏览 0 评论
飞凌嵌入式-ELFBOARD-ELF 2硬件知识分享之Debug
1057 浏览 1 评论
飞凌嵌入式ElfBoard ELF 1板卡-烧录流程介绍之单独更新内核
2680 浏览 1 评论
飞凌嵌入式ElfBoard ELF 1板卡-TF卡烧录流程之烧写过程
1106 浏览 0 评论
GMT+8, 2025-1-14 08:33 , Processed in 0.766610 second(s), Total 67, Slave 50 queries .
