TIwilliam hill官网
刘琨
7年用户 200经验值
请问导致c6455load出错的原因是什么?C6455在load的时候要另外注意什么?
只是一个小程序,显示这个错误,Loader: One or more sections of your program falls into a memory region that is not writable.Loader: One or more sections of your program falls into a memory region that is not writable. Check your linker configuration and/or memory map。
不知道C6455在load的时候要另外注意什么。
回帖(6)
刘琨
2018-6-25 00:30:05
刚才错误没打完,补上:Trouble Writing Register: Error 0x00000006/-1176 Error during: Memory, Register,  The IM memory request is not serviced by the HW memory system. This could be caused by the memory address specified does not exist in the specified  memory/cache level.    Sequence ID: 6 Error Code: -1176 Error Class: 0x00000006
李桂花
2018-6-25 00:43:53
引用: 60user160 发表于 2018-6-25 00:30
刚才错误没打完,补上:Trouble Writing Register: Error 0x00000006/-1176 Error during: Memory, Register,  The IM memory request is not serviced by the HW memory system. This could be caused by the memory address specified does not exist in the specified  memory/cache level.    Sequence ID: 6 Error ...
Hu Shushu:
你好!
不知道你的link command文件是否和硬件一致?如果工程不大试试附件里面的文件。
谢谢!
刘琨
2018-6-25 00:49:32
引用: 宝弟弟弟 发表于 2018-6-25 00:43
Hu Shushu:
你好!
谢谢楼上Yu Liu ,我用了你的cmd还是不行,想问一下C6455的libraries应该include什么文件,有什么区别么。我include的是rts64plus.lib.
李桂花
2018-6-25 01:08:08
rts64plus.lib应该没有问题。请问你是通过emulator加载到硬件还是加载到simulator?
