我已经看过AD9467的评估板在ZEDboard和KC705的引脚约束为"LVDS_25",对应FPGA的BANK VCCO供电2.5V,但是现在我的项目中FPGA BANK 的VCCO供电是1.8V,我对其做引脚约束为"LDVS"可行吗?
I am no FPGA expert, but i believe that LVDS is an ANSI standard. The standard depends on the differential swing of signals around a common mode voltage of ~1.2V. See datasheet excerpt below:
So if your FPGA supports this mode, then the AD9467 should be able to send data to your FPGA. 答案来源:The output of the AD9467 is LVDS level standard... | EngineerZone |
1024 浏览 2 评论
1410 浏览 2 评论
1954 浏览 1 评论
4283 浏览 2 评论
9083 浏览 1 评论
1603浏览 3评论
1709浏览 2评论
1027浏览 2评论
1697浏览 2评论
1413浏览 2评论
GMT+8, 2025-1-4 10:41 , Processed in 0.701142 second(s), Total 46, Slave 40 queries .
