想用10kHz鉴相频率,输出信号从2.50GHz频率开始以10Hz为间隔的一系列频率,参考信号源是10MHz。
直接使用10MHz鉴相时,频率间隔最小只有1kHz,尝试更小间隔时频谱仪显示输出频率无变化。
但改用10kHz之后,芯片始终无法锁定(另外还发现,无论R、N、FRAC寄存器如何配置,只要VCO输出分频写入0x1210,就会显示锁定,频率为82.5MHz)。
寄存器配置如下:
REG 1 2 //
REG 2 3E8 // Ref Divider =1000
REG 5 90 // Reg02 = 000000001 = fo (VCO output Div-by-1)
REG 5 4F98 // Reg03 = 000011011 = High Performance Mode, RF_P&RF_N enabled, 5dB RL, mute VCO when VCO op divider set to 0.
REG 5 4DB8 // maximum o/p power
REG 5 0 // Close out VCO register programming by wri
ting Reg 5 = 0.
REG 6 2003CA // Delta-Sigma Modulator Configuration Register. Programmed for Int Mode
REG 7 2CD // Lock Detect. 8192 counts of divided VCO must land inside 1/(2*fpd) digital window (50 ns for 10MHz).
REG 8 C1BEFF // Default value = C1BEFFh. No need to program.
REG 9 203EFD // CP Register. 2mA CP gain current, no CP Offset current.
REG A 2046
REG C 0 // Exact Frequency register. Default value =0h. No need to program if not using Exact Frequency Mode.
REG F 81 // LD configuration. Default value =1h. 81h sets LD/SDO to output LD status always except during register reads.
REG 3 3D090 // Integer VCO Divider Register-Prog
ARM as needed to set frequency.
REG 4 0
环路滤波器配置如下:
希望高手解答,谢谢
