Cypress技术william hill官网
李国东
7年用户 191经验值
PSoC Creator 3.3 Error M0094
嗨,我有一个旧的项目从2016我使用PSoC Creator 3.3建。
CY8C5868 AXI-LP032。
我经常重建和程序没有问题。
现在,当我增设的PSoC Creator 4.2,我得到错误m0094当我打开旧项目与PSoC Creator 3。
它说,一个设计广泛的资源文件是项目或外部修饰。
建成后,该项目不能正常运行。我不知道出了什么问题。最明显的是,显示
这是连接多个GPIO引脚不显示任何东西。
当我使用PSoC编程的程序员老HEX文件,运行如预期。
我能做的能够使用旧的项目没有错误,可以修改旧的文件是什么?
以上来自于百度翻译
        以下为原文
                                            Hi, I have an old project from 2016 that I have built using PSoC Creator 3.3.
CY8C5868AXI-LP032.
I have frequently rebuilt it and programmed it without problems.
Now, after I additionally installed PSoC Creator 4.2, I get the error M0094 when I open the old project with PSoC Creator 3.3.
it says that a design wide resource file has been modified outside the project or so.
After build, the project does not run correctly. I am not sure what is wrong. The most obvious thing is that a display
that is connected to several GPIO pins does not show anything.
When I use the PSoC Programmer to program the old hex file, it runs as expected.
What can I do to be able to use the old project without errors and to be able to modify the old file?
回帖(3)
h1654155275.5782
2018-8-15 08:05:29
当你打开项目中的PSoC Creator,你有任何更新的组件来构建?
如果是这样的话,你读的成分变化部分,看看是否有任何可能影响你项目的功能性成分的变化?
以上来自于百度翻译
        以下为原文
                                            When you open the project in PSoC Creator, do you have to update any components to build?
If so, have you read the Component Changes section to see if there are any component changes that might affect the functionality of your project?
孙乙鑫
2018-8-15 08:23:45
如果双击项目/工作区,默认情况下它将在最后安装的PSoC Creator版本中打开。看来你的项目是在PSoC开的创造者4.2至少一次。如果你有项目的备份,请继续使用创造者3.3。否则,请使用创建者4.2而不是创建者3.3。
以上来自于百度翻译
        以下为原文
                                            If you double click the project / workspace, it will open in the last installed PSoC Creator version by default. It seems that your project is opened in PSoC Creator 4.2 atleast once. If you have project backup, please continue to use Creator 3.3. Else, please use Creator 4.2 instead of Creator 3.3.
李国东
2018-8-15 08:37:44
                    以上来自于百度翻译
谢谢,你是对的。
在我恢复的项目从一个备份,从未被PSoC Creator 4.2感动,它再次成功。
以上来自于百度翻译
        以下为原文
                                            Thanks, you were right.
After I restored the project from a backup that has never been touched by PSoC Creator 4.2, it worked again.
