ADI 技术
郝汉
7年用户 182经验值
AD5754R和STM32通过SPI通讯无输出
使用STM32F103与AD5754R通过SPI2进行通讯,时序通过示波器来检查都正确,但是没有输出。
1. 我的硬件威廉希尔官方网站 如下图
2. 软件如下。
主函数如下
int main(){    HW_init();  AD5754R_SetPower(AD5754R_DAC_ALL, 0x1);  delay_ms(1);  AD5754R_RangeSelect(AD5754R_DAC_ALL, AD5754R_UNIPOLAR_5_RANGE);  delay_ms(1);  for(;;) {  AD5754R_LoadDac(AD5754R_DAC_ALL, 0xFFFF);  delay_ms(1);  }    return 0;}
其中,硬件的SPI2初始化如下。
/** PB10---SPI2_LDAC()* PB11---SPI2_SYNC* PB12---SPI2_NSS* PB13---SPI2_SCK* PB14---SPI2_MISO (暂时没用到)* PB15---SPI2_MOSI*/void SPI2_Init() {  GPIO_InitTypeDef GPIO_InitStructure;  SPI_InitTypeDef SPI_InitStructure;  RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE );//PORTB 时钟使能   RCC_APB1PeriphClockCmd( RCC_APB1Periph_SPI2,  ENABLE );//SPI2 时钟使能   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11;  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;  GPIO_Init(GPIOB, &GPIO_InitStructure);  GPIO_ResetBits(GPIOB, GPIO_Pin_10);//LDAC 低有效  GPIO_SetBits(GPIOB, GPIO_Pin_11);//SYNC 低电平有效  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//复用推挽输出  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;  GPIO_Init(GPIOB, &GPIO_InitStructure);  GPIO_SetBits(GPIOB, GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15);//上拉  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;//全双工  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;//Master  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;//软件控制NSS  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;  //SPI_InitStructure.SPI_CRCPolynomial = 7;  SPI_Init(SPI2, &SPI_InitStructure);//根据设定的参数,初始化外设SPIx寄存器  SPI_Cmd(SPI2,ENABLE);//使能外设  SPI2_ReadWriteByte(0xff);//启动传输}
//SPI 速度设置函数//SpeedSet://SPI_BaudRatePrescaler_2   2分频   //SPI_BaudRatePrescaler_8   8分频   //SPI_BaudRatePrescaler_16  16分频  //SPI_BaudRatePrescaler_256 256分频 void SPI2_SetSpeed(u8 SPI_BaudRatePrescaler) {  assert_param(IS_SPI_BAUDRATE_PRESCALER(SPI_BaudRatePrescaler));  SPI2->CR1&=0XFFC7;  SPI2->CR1|=SPI_BaudRatePrescaler; //设置SPI2速度   SPI_Cmd(SPI2,ENABLE); }
在SetPower的时候,我直接在PowerControl寄存器中的后四位写入F。
newPowerCtl = 0x000F;AD5754R_SetRegisterValue(AD5754R_REG_POWER_CONTROL, 0x00, newPowerCtl);//TODO
通过SPI写入函数如下
/*发送24位Data*/void WriteToAD5754RViaSPI(u32 data) {  u8 high;  u8 middle;  u8 low;  high = (u8)((data>>16)&(0x000000FF));  middle = (u8)((data>>8)&(0x000000FF));  low = (u8)((data&(0x000000FF)));  //SPI start  GPIO_SetBits(GPIOB, GPIO_Pin_11);//SYNC 置高  delay_ns(100);//最少100ns  GPIO_ResetBits(GPIOB, GPIO_Pin_11);//清零  delay_ns(2);  SPI2_ReadWriteByte(high);  SPI2_ReadWriteByte(middle);  SPI2_ReadWriteByte(low);  delay_ns(20);//至少13ns  GPIO_SetBits(GPIOB, GPIO_Pin_11);}
其他地方,我都测试过,输入的波形都是对的,
波形高电平电压为5V。
我没有接SDO接口。
但是,现在,无论怎么操作,都没法输出数据,求问,是硬件威廉希尔官方网站 问题吗???
谢谢大家
回帖(5)
袁飞
2018-8-18 06:52:17
看了硬件,没有发现发问题,
软件方面可以参考附的示例代码,对比检查一下
附件
郝汉
2018-8-18 07:00:35
引用: 60user105 发表于 2018-8-18 06:52
看了硬件,没有发现发问题,
附件
你看AD5754的14号管脚,datasheet上是要接数字电源正,我总觉得这里是不是应该和ADuM1410的16号管脚是同一个电源正。
AD5754输入的信号的高电位有5V。
hpkamen
孙秀英
2018-8-18 07:20:29
AD5754输入的信号的高电位有5V。
没错,AD5754的14脚是DVCC,应该和数字信号共电源。
郝汉
2018-8-18 07:32:43
嗯,谢谢您。
已经改为+5V供电,硬件上应该没有什么问题了吧,已经不知道哪里出问题了。
软件思想是和例程差不多的。
