为了访问Cortex ™ -M3 TAP 对芯片进行调试,必须:
1. First, it is necessary to shift the BYPASS instruc
tion of the boundary scan TAP.
2. Then, for each IR shift, the scan chain contains 9 bits (=5+4) and the unused TAP instruction must be shifted in using the BYPASS instruction.
3. For each data shift, the unused TAP, which is in BYPASS mode, adds 1 extra data bit in the data scan chain.
Note: Important : Once Serial-Wire is selected using the dedicated ARM JTAG sequence, the boundary scan TAP is automatically disabled (JTMS forced high)。
以上该如何理解???
现在IDCODE可以读到,但是读写有问题。
①for each IR shift, the scan chain contains 9 bits (=5+4) and the unused TAP instruction must be shifted in using the BYPASS instruction.
该如何实现?
②For each data shift, the unused TAP, which is in BYPASS mode, adds 1 extra data bit in the data scan chain.
adds 1 extra data bit是放在最后移入吗?
该如何实现正确读写?
请教大神指导指导!
是否有Demo可供参考?
