我正在使用VMWARE ESXi 6.5测试服务器Dell R720XD + Grid K2
遇到的问题是VMWARE会出现红屏。
根据制造商的建议,我使用戴尔版本的VMWARE升级了戴尔的最新BIOS;
我试图扩大内存容量和
电源,以及所有无法解决的问题,仍然无法解决VMWARE崩溃问题。
当我没有安装K2驱动程序,或者没有在虚拟机中启用K2相关配置时,整个系统一切正常,一旦启用K2相关配置,无论哪种驱动模式,都会导致快速出现
VMWARE红屏情况
我判断可能与K2的散热有关,因为我觉得K2温度很高,而且我用命令查看设备情况,发现温度高达95摄氏度。
2017年3月8日星期三15:12:34
NVIDIA-SMI 367.64驱动程序版本:367.64 |
GPU名称持久性-M |
Bus-Id Disp.A |
挥发性的Uncorr。
ECC |
Fan Temp Perf Pwr:用法/上限|
内存使用|
GPU-U
til Compute M. |
0 GRID K2开|
0000:44:00.0关闭|
关|
N / A 98C P8 34W / 117W |
3837MiB / 4095MiB |
0%默认值|
1 GRID K2开|
0000:45:00.0关闭|
关|
N / A 81C P8 31W / 117W |
3837MiB / 4095MiB |
0%默认值|
进程:GPU内存|
GPU PID类型进程名称用法|
0 68203 C + G WIN10 B 3824MiB |
1 68202 C + G WIN10 A 3824MiB |
这个温度K2可以正常运行吗?
因为K2是被动冷却模式,而我没有找到相关参数,无法确认温度的安全运行?
如果我必须改善热量问题,我该怎么办?
以上来自于谷歌翻译
以下为原文
I'm testing a server, Dell R720XD + Grid K2, using VMWARE ESXi 6.5
The problem encountered is VMWARE will appear red screen.
According to the manufacturer's advice, I upgraded Dell's latest BIOS, using the Dell version of VMWARE;
I tried to expand the memory capacity and power supply, and all the problems that can not be solved, still can not solve the VMWARE crash problem.
When I do not install K2 driver, or not in the virtual machine to enable K2-related configuration, the whole system everything is normal, once I enable K2-related configuration, no matter what kind of drive mode, will lead to the rapid emergence of VMWARE red screen situation The
I judge may be related to the heat dissipation of K2, because I feel K2 temperature is very high, and I use the command to view the equipment situation, the temperature was found as high as 95 degrees Celsius.
Wed Mar 8 15:12:34 2017
| NVIDIA-SMI 367.64 Driver Version: 367.64 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GRID K2 On | 0000:44:00.0 Off | Off |
| N/A 98C P8 34W / 117W | 3837MiB / 4095MiB | 0% Default |
| 1 GRID K2 On | 0000:45:00.0 Off | Off |
| N/A 81C P8 31W / 117W | 3837MiB / 4095MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 68203 C+G WIN10 B 3824MiB |
| 1 68202 C+G WIN10 A 3824MiB |
Will this temperature K2 can run properly? Because K2 is a passive cooling mode, and I did not find the relevant parameters, can not confirm the safe operation of the temperature?
What should I do if I have to improve the heat problem?
