正如JAson所说,我们为虚拟化供应商提供了实现分配的API,但实施和控制它的是VMware / Citrix,因此针对该行为的功能请求/错误应该由Citrix / VMware提供。
我知道vSPhere的一个警告(已知问题) - 我不确定他们是否已经解决了可能值得阅读您正在使用的版本的驱动程序发行说明并检查您是否看到它:http://
nvidia.custhelp.com/app/answers/detail/a_id/4129/kw/vmware%20known%20issues(ctrl-f for“allocation”) - 如果你确实看到它使用VMware记录了一张票,那么他们就会发现修复。
也许值得在VMwarewilliam hill官网
上评论您的需求(有一个特定的NVIDIA),因此您的需求会突出显示。
最好的祝愿,
雷切尔
以上来自于谷歌翻译
以下为原文
As JAson says we provide the virtualisation vendors the APIs to implement allocation but it is VMware/Citrix who implement and control it so feature requests/bugs against that behaviour should got to Citrix/VMware.
I am aware of one caveat (known issue) with vSPhere - that I'm not sure has been resolved by them it might be worth reading the driver release notes for the version you are using and checking if you see it: http://nvidia.custhelp.com/app/answers/detail/a_id/4129/kw/vmware%20known%20issues (ctrl-f for "allocation") - if you do see it log a ticket with VMware so they issue with a fix.
It might also be worth commenting on your needs on the VMware forums (there's an NVIDIA specific one) so your need is highlighted with them.
Best wishes,
Rachel
最好的祝愿,
雷切尔
以上来自于谷歌翻译
以下为原文
Best wishes,
Rachel
