ST意法半导体
黄明光
7年用户 331经验值
指南针的建议
你好。
新年快乐 !
我想使用ST罗盘+加速度计芯片(2合1)之一来实现卡尔曼滤波器中的模拟设备陀螺仪之一。
你提供哪种传感器?选择合适传感器的标准是什么?我需要最准确和最稳定的一个。
Ragards
以上来自于谷歌翻译
以下为原文
Hi.
Happy new year !
I'd like to use one of ST compass + accelerometer chip (2 in 1) for implementing with one of analog device gyroscope in Kalman filter.
Which sensor do you offer?  what is the criteria of choosing the right sensor? i need most accurate and stable one.
Ragards
回帖(1)
曾玲娟
2018-9-10 17:27:59
我建议你考虑以下三个传感器:
http://www.st.com/content/st_com/en/products/mems-and-sensors/e-compasses/lsm303agr.html
,http://www.st.com/content/st_com/en/products/mems-and-sensors/e-compasses/lsm303c.html
,http://www.st.com/content/st_com/en/products/mems-and-sensors/e-compasses/lsm303ah.html
 (仅1.8V Vcc)。标准实际上取决于您的应用和要求,可能是:电流消耗,FS范围/灵敏度,可用输出数据速率,封装尺寸,噪声,......
以上来自于谷歌翻译
以下为原文
I would recommend you to consider following three sensors:
, http://www.st.com/content/st_com/en/products/mems-and-sensors/e-compasses/lsm303c.html
, http://www.st.com/content/st_com/en/products/mems-and-sensors/e-compasses/lsm303ah.html
(only 1.8V Vcc).The criteria really depends on your application and requirements, it could be: current consumption, FS ranges/sensitivity, available output data rates, package size, noise, ...
