我不确定服务器2016,但是2012和Citrix让我也被困了一段时间。
Internet Explorer根本不使用任何图形加速,也无法使用它。
我建议你安装chrome,检查chrome:// gpu以查看加速是否有效,或者使用--ignore-gpu-blacklist开关强制它,看看它是做什么的。
另请参阅此Citrix KB:
XenApp for Windows Server(2012 R2和2008 R2)上的Internet Explorer未加速GPU加速
https://support.citrix.com/article/CTX204161
办公室应该是办公室政策,应该可以正常运作。
还要检查您的Citrix策略,确保旧版图形已关闭,并且您的协议是Thinwire或Framehawk,具体取决于您的具体情况。
EDT非常值得,因为它授予您UDP流量而不是TCP流量。
性能方面你应该可以毫不费力地运行1080p youtube,谷歌Chrome不使用太多的CPU(10到30%的顶部)。
最后一个想法,我假设你已经安装了GRID许可证?
以上来自于谷歌翻译
以下为原文
I'm not sure about server 2016, but 2012 and Citrix had me stumped for a while too. Internet Explorer does not use any graphics acceleration at all, and cannot use it. I would suggest you install chrome, check with chrome://gpu to see whether the acceleration works, or force it with the --ignore-gpu-blacklist switch and see what that does.
Also see this Citrix KB:
Internet Explorer is Not GPU-Accelerated on XenApp for Windows Server (2012 R2 and 2008 R2)
Office should be an office policy and should work fine.
Also check your citrix policies, make sure that legacy graphics is off and your protocol is either Thinwire or Framehawk, depending on your situation. EDT is well worth it, as it grants you UDP traffic instead of TCP.
Performance wise you should be able to run 1080p youtube without a hitch, with Google Chrome not using too much cpu (10 to 30% tops).
Just a last thought, i'm assuming you've installed your GRID licenses?
另请参阅此Citrix KB:
以上来自于谷歌翻译
以下为原文
