嗨,我在互联网上搜索了飞行时间技术的确切原理,但我得到的答案在不同的网站上有所不同。我最近购买了VL53l0X传感器,我需要ST产品TOF的确切原理。
以上来自于谷歌翻译 以下为原文 Hi, i searched for the exact principle of the time of flight technology in internet but the answer i got was different in different websites. I bought VL53l0X sensor recently and i need the exact principle of TOF of ST's product. |
大部分信息都在
http://www.st.com/content/ccc/resource/technical/document/datasheet/group3/b2/1e/33/77/c6/92/47/6b/DM00279086/files/DM00279086.pdf/jcr:内容/翻译/ en.DM00279086.pdf :来自垂直激光器的红外脉冲的爆发以锥形立体角发射。 如果存在物体,则反射光束将被雪崩照片diod感测到。 通过测量从发射到接收光脉冲所花费的时间来计算距离。 每皮秒0.299792毫米==> 1mm对应于~3 ps时间粒度实现 以上来自于谷歌翻译 以下为原文 Most of the information is in the http://www.st.com/content/ccc/resource/technical/document/datasheet/group3/b2/1e/33/77/c6/92/47/6b/DM00279086/files/DM00279086.pdf/jcr:content/translations/en.DM00279086.pdf :Burst of infrared pulses from vertical laser is emitted in a cone shaped solid angle. If there is an object, the reflected light beam will be sensed by the avalanche photo diod. The distance is calculated by mesuring the time it took from emission to reception of a light pulse. 0.299792 mm per picosecond ==> 1mm correspond to ~3 ps time granularity implementation |
还有一个关于校准的疑问。偏移校准是在任何特定的测距模式下完成的,例如长距离,高精度和高速吗?
以上来自于谷歌翻译 以下为原文 And also one more doubt on Calibration. Is offset calibration done in any specific ranging mode such as long range, high accuracy and high speed? |
2785 浏览 1 评论
3252 浏览 1 评论
1827 浏览 1 评论
3672 浏览 6 评论
6068 浏览 21 评论
1352浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
374浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
470浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
294浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
218浏览 2评论
GMT+8, 2025-1-14 10:47 , Processed in 1.065093 second(s), Total 77, Slave 61 queries .
