我尝试使用IFBW设置命令,就像我在E8363B中使用的那样,即“SENS:BWID 100”,但是这个命令对于N5242不起作用,而在标准脉冲模式下使用它,我可以手动设置IFBW,但不能通过编程。
当我不使用脉冲模式时,相同的命令工作。 我还禁用脉冲模式下的自动IFBW设置,即“SENS:SWE:PULS:IFBW 0”,但无法成功。 你能告诉我一些合适的方法吗? 另外,请告诉我,在窄带检测模式下,IFBW是否低于自动调整值会有利还是会造成劣势? 以上来自于谷歌翻译 以下为原文 I tried IFBW setting command just like I used in E8363B i.e “SENS:BWID 100”, but this command didn’t worked for N5242 while using this in standard pulse mode, I can set IFBW manually but could not by programming . When I do not use pulse mode, the same command works. I also disable automatic IFBW setting in pulse mode i.e “SENS:SWE:PULS:IFBW 0” but could not succeed. Could you please tell me some appropriate way? Furthermore, plz tell me, in narrow band detection mode, whether IFBW lower than auto adjusted value will be beneficial or cause disadvantage? |
不确定原因。
您使用的是什么FW rev? RBW与脉冲重复频率有很大限制,可能是您无法为已设置的PRF设置100 Hz。 您可能需要先手动完成并记录脉冲应用程序提供的PRF的确切值,然后再远程设置,然后设置IF BW。 我自己没试过(从未编程脉冲模式)。 以上来自于谷歌翻译 以下为原文 Not sure of the reason for this. What FW rev are you using? There is a strong limit on the RBW vs pulse repetition frequency, and it may be that you can't set 100 Hz for the PRF that you have set. You might need to do it manually first and record the exact values of the PRF that the pulse-app gives and then remotely set that first, and then set the IF BW. I haven't tried this myself (never programmed pulse mode). |
1322 浏览 0 评论
2393 浏览 1 评论
2213 浏览 1 评论
2083 浏览 5 评论
2967 浏览 3 评论
1210浏览 1评论
778浏览 0评论
1011浏览 0评论
1322浏览 0评论
GMT+8, 2025-1-9 03:18 , Processed in 1.362359 second(s), Total 74, Slave 58 queries .
