大家好,我是新的PIC,所以请指导我如果我犯了任何错误。我试图产生一个PWM信号为500千赫频率。占空比在25%至50%的范围内的降压转换器(800 W)。我找不到PIC微控制器(8位优选),可以产生一个稳定的PWM为500公里。我的问题是,最大的PWM频率可以用PIC18、PIC16和PIC12微控制器产生,什么优化可能导致这个输出。此外,我需要计时器和时钟频率的计算。先谢谢你。
以上来自于百度翻译
以下为原文
Hi Everyone,
I am new to the PIC so please guide me if I am making any mistake(s).
I am trying to generate a PWM signal of 500Khz freq. with a duty cycle in the range of 25%to 50 % for a buck converter(800W).
I cannot find a PIC microcontroller (8bit preferred) which can generate a stable PWM of 500Khz.
my ques
tion is, what is the maximum PWM freq. that can be produced with pic18, pic16 and pic12 microcontrollers
and what optimizations might lead to this output.
Also, I need the calculations for timer and clock freq. required?
Thank You in advance.
