用于归档ADS工作空间的7zads格式直到ADS 2014.01才会引入,因此无法在ADS 2011.xx中直接从中提取数据。
此版本仅支持较旧的7zap格式。
可以通过运行7-Zip或支持.7z压缩文件格式的任何其他工具手动从7zads文件中提取数据。
在$ HPEESOF_DIR / bin / 7zFM.exe下,ADS for Windows附带了7-Zip文件管理器的副本。
如果使用此方法打开7zads文件,则可以从那里提取文件。
但问题是,为了获得7zads存档,工作空间必须已从ADS 2014.01或更高版本保存,因此它可能包含使用ADS 2011.xx之后引入的特性和功能的设计,因此这些设计无法工作
可能会生成ADS 2011.xx以及有关不支持的设置的错误信息。
以上来自于谷歌翻译
以下为原文
The 7zads format for archiving ADS workspaces was not introduce until ADS 2014.01 so it would not be possible to directly extract the data from it in ADS 2011.xx. This version only supports the older 7zap format.
It is possible to manually extract the data from the 7zads file by running 7-Zip or any other tool that supports the .7z compressed file format. A copy of 7-Zip File Manager is shipped with ADS for Windows under $HPEESOF_DIR/bin/7zFM.exe. If you open the 7zads file using this you can then extract the files from there.
The problem with this though is that to get to a 7zads archive the workspace would have to have been saved from ADS 2014.01 or later so it may contain designs using features and capabilities that were introduced after ADS 2011.xx and therefore these would not work on ADS 2011.xx and error meaasges about unsupported settings may be generated.
此版本仅支持较旧的7zap格式。
以上来自于谷歌翻译
以下为原文
