您能否确认“3D渲染器”的池设置是否设置为“NVIDIA GRID VGPU”?
已添加到VM的设备是“共享PCI设备”== vGPU还是“PCI设备”== vDGA?
如果设置了此项并且您无法选择要用于主映像的VM,请确认所选映像已分配了vGPU设备,并且已存在于已安装vGPU管理器振动的主机上。
以上来自于谷歌翻译
以下为原文
Can you please confirm the pool setting for the "3D Renderer" is set to "NVIDIA GRID VGPU"?
Is the device that has been added to the VM a "Shared PCI Device" == vGPU or a "PCI Device" == vDGA?
If this is set and you are unable to select a VM to be used for the master image, please confirm the image selected has a vGPU device assigned and exists on a host where the vGPU manager vib has been installed.
以上来自于谷歌翻译
以下为原文
