英伟达
范亚娟
7年用户 236经验值
VM Win7 Xenserver 7 Nvidia Grid 369.71驱动程序不应用
大家好;
我全新安装了Xenserver 7.0并应用了所有发布补丁。
该服务器是戴尔R720,它有两个nvidia K2卡,我还从公共Nvidia驱动程序网站安装了nvidia网格驱动程序367.64 rpm文件。
比我在该主机服务器上创建Win 7 sp1 x64 vm。
我安装了从同一个包Xenserver Nvidia驱动程序中提取的nvidia grid 369.71驱动程序。
驱动程序安装到客户端Win 7 vm重新启动它但检查它nvidia网格驱动程序不应用。
我检查过设备管理器K240驱动程序图标仍然有黄色三角形。
这是任何人遇到这个问题吗?
你能告诉我我的步骤有什么不对吗?
最好的祝福
以上来自于谷歌翻译
以下为原文
Hi everybody;
I fresh installed Xenserver 7.0 and applied all release patch. That server is Dell R720 and it has two nvidia K2 card, I also installed nvidia grid driver 367.64 rpm file from public Nvidia driver web sites. Than I created Win 7 sp1 x64 vm on that host server. I installed nvidia grid 369.71 driver which extracted from same pack Xenserver Nvidia drivers. After driver install to guest Win 7 vm reboot it but checked it nvidia grid driver do not applied. I checked device manager K240 driver icon still has yellow triangle.
is this any one encounter this issue?
Could you please advice me what is wrong my steps?
Best regards
回帖(2)
李耘蝶
2018-9-19 17:14:00
嗨,
您是否在主机上检查了nvidia-smi以查看vGPU管理器是否已正确安装?
请同时使用:rpm -qa |
grep -i Nvidia显示你安装的rpm。
问候
西蒙
以上来自于谷歌翻译
以下为原文
Hi,
did you check with nvidia-smi on the host to see if the vGPU manager is properly installed ?
Please also use: rpm -qa | grep -i Nvidia to show the rpm you installed.
Regards
Simon
张海燕
2018-9-19 17:24:54
嗨sschaber;
我们的问题在下面的文章中解决
https://discussions.citrix.com/topic/378741-xenserver-70-k1k2-driver-upgrade-issue/
最好的祝福
以上来自于谷歌翻译
以下为原文
Hi sschaber;
Our problem was solved below article
best regards
