你好,
我们刚刚在一些HP ProLiant WS460c Gen9s刀片上使用VMware ESXi,6.0.0,3620759安装了一些M6卡。 在任何操作系统(Win7 / 10,Server2008R2)上使用vGPU并启动某些应用程序(如GPU-Z或3DMark 11)时,VM将显示蓝屏并重新启动。 这似乎是任何卡配置文件的情况。 只想询问这是否与驱动程序版本或配置问题有关。 在发布文档的“已知问题”中没有看到任何相关内容。 有什么想法吗? 以上来自于谷歌翻译 以下为原文 Hello, We just installed some M6 cards using VMware ESXi, 6.0.0, 3620759 on some HP ProLiant WS460c Gen9s blades. When using the vGPU on any OS (Win7/10, Server2008R2) and launching certain apps, like GPU-Z or 3DMark 11, the VM will blue screen and reboot. This appears to be the case for any of the card profiles. Just want to ask if this is related to the driver version or a config issue. Haven't seen anything about this in the "known issues" of the release docs. Any thoughts? |
5个回答
你好,
我一直在遇到类似的问题。 在安装Nvidia驱动程序之前是否安装了VMtools? 以上来自于谷歌翻译 以下为原文 Hello, I've been encountering the similar issues. Was VMtools installed before Nvidia driver is installed? |
嘿咖啡,
这些工具安装在卡驱动程序之前。 其他基准测试工具的推出和运行,如Unigine Heaven或Specviewpefc。 进程监视器也可以读取GPU信息,但与nvidia-smi.exe相比,内存和GPU%数字不准确。 以上来自于谷歌翻译 以下为原文 Hey Coffee, The tools were installed before the card driver. Other benchmark tools launch and run, like Unigine Heaven or Specviewpefc. Process monitor can also read GPU info, though the memory and GPU % figures are not accurate compared to nvidia-smi.exe. |
嘿Gillilanded,
CUDA或OpenCL是否正在运行? vGPU功能怎么样? M6-8Q或M6-8A还是什么? 当然,你已经申请了vGPU许可证,对吧? 以上来自于谷歌翻译 以下为原文 Hey Gillilanded, Are CUDA or OpenCL running on it? How about vGPU features? M6-8Q or M6-8A or something? Of course, you have applied a vGPU license on it, right? |
嗨,
至少GPU-Z的问题是众所周知的。 在问题得到解决之前,请勿使用最新版本的GPU-Z。 我没有使用3DMark的经验。一般来说,在GRID环境中运行人工基准测试没有多大意义。 如果您需要运行基准测试(对于单个正在运行的VM),Unigene Heaven应该可以工作。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi, at least the issues with GPU-Z are well known. Don't use the latest versions of GPU-Z until the issue is fixed. I don't have experience with 3DMark, In general it makes not much sense to run an artificial benchmark on a GRID environment. Unigene Heaven should work if you need to run a benchmark (for a single running VM). Regards Simon |
嗨,
不确定这是否相关,但Windows的NVIDIA驱动程序369.71似乎包含NVIDIA CUDA或OpenCL进程文件。 如果正确,以下配置文件支持NVIDIA CUDA或OpenCL。 M60-8Q和8A M6-8Q和8A 以上来自于谷歌翻译 以下为原文 Hi, Not sure this is related but NVIDIA driver 369.71 for Windows seems like contains NVIDIA CUDA or OpenCL process files. If correct, NVIDIA CUDA or OpenCL are supported on the following profiles. M60-8Q and 8A M6-8Q and 8A |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3184 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3592 浏览 4 评论
GMT+8, 2025-3-7 11:07 , Processed in 0.658131 second(s), Total 83, Slave 67 queries .
