This high speed digital output module ti Design for programmable logic controllers (PLCs) illustrates the design of low-cost, simple high speed single-ended digital output module using standard low side driver and backplane powered using isolated power stage. High speed digital output modules are (...)
主要特色
4 high speed digital outputs
External load power
Single-ended outputs working up to : 500 kHz with 5 V field power, 100 kHz with 24 V filed power
210 mW power consumption from backplane isolated power stage
Less than 100 ns transition time with 15 m cable
300 mW power consumption per load for 5 V supply (...)
