嗨,
我有3个Dell R730,每个服务器配置2个NVIDIA GRID K2板。
我通过在我的一台ESXi服务器上激活直通模式,将1个GPU专用于VM。
在启动应用程序Image Generator(Genesis IG)时,我注意到我的GPU实际使用率为99%,这解释了一些不太好的性能,它接近常规PC上的GeForce 970GTX所提供的但还没有真正存在
为了解决性能问题,我决定在passthough模式下为这台机器添加另一个GPU,现在我已经安装了2个GRID GPUS并显示在我的VM上。
我的问题是,可以让2 GPUS在多GPU支持概念或SLI中协同工作吗?
现在,如果我启动相同的应用程序,我只能看到1个GPU工作,另一个是0%。
单个GPU可能足以运行IG,如果我不必浪费25%的GPU用于PCoIP会话单独进入我的Zero客户端。
谢谢
帕斯卡尔
以上来自于谷歌翻译
以下为原文
Hi,
I have 3 x Dell R730s configured with 2 x NVIDIA GRID K2 boards in each servers. I have dedicated 1 GPU to a VM by ac
tivating the passthrough mode on one of my ESXi server. When launching an application Image Generator (Genesis IG), I have noticed that my GPU was actually being used at 99% which explains some not so good performance, it is close to what the GeForce 970GTX on a regular pc provides but not really there yet.
In order to address the performance issue I have decided to add another GPU to this machine in passthough mode and I have now 2 GRID GPUS installed and showing up on my VM. My question is it possible to have the 2 GPUS working together in a multi-gpu support concept or SLI? Right now if I launch the same application I can only see 1 GPU working and the other one is at 0%. A single GPU would probably be enough to run the IG if I didnt have to waste 25% on the GPU for the PCoIP session alone going to my Zero client.
Thanks
Pascal
