Qualcomm技术william hill官网
李韵鹤
7年用户 132经验值
基于Dragonboard 410c的智能遥控器软件实现
     之前已经做过智能遥控器的硬件介绍,这里就不再详细赘述了,现在主要看看软件实现。
#include
#include
#include
#include
#include
#include
#include
#include
#include timer.h>
#include
#include
#include
#include
#include
#include
#include
#include "et4007.h"
#define DEVICE_NAME        "irremote"
#define DRIVER_NAME        "et4007"
#define START_DELAY     200
#define STOP_DELAY      200
#define CLK_DELAY       50
static DECLARE_WAIT_QUEUE_HEAD(remote_waitq);
static volatile int busy_status = 0;
struct timer_list remote_timer;
struct class *et4007_class = NULL;
static int et4007_compare_alldata(struct remote_data rmt_data, uint16_t *sample, int index)
    int i;
    uint16_t timeHigh, timeLow;
    for (i = 0; i < index; i += 2) {
        timeHigh = sample;
        timeLow = sample[i + 1];
        if (et4007_compare_time(rmt_data, timeHigh, timeLow)) {
            return 1; // rmt_data is equal sample data
    return 0; // rmt_data is not equal sample data
static void et4007_push_sample_time_data(struct remote_data data, uint16_t *sample, int index)
    sample[index] = data.high_level;
    sample[index + 1] = data.low_level;
int et4007_get_index(struct remote_data data, uint16_t *sample, int index)
    int i = 0;
        timeHigh = sample;
        timeLow = sample[i+1];
        if (et4007_compare_time(data, timeHigh, timeLow)) {
            return i;
    return 32;
static int et4007_get_data_index(struct ir_remocon_data *ir_data)
    int i, j = 0, count = 0;
    char temp;
    struct remote_data rmt_data;
    for (i = 0; i < ir_data->count; i += 2) {
        rmt_data.high_level = ir_data->original;
        rmt_data.low_level = ir_data->original[i+1];
        temp = et4007_get_index(rmt_data, ir_data->sample, ir_data->index);
        if (temp > 32) {
            return -1;
        ir_data->data[count++] = (temp / 2) ;
    ir_data->couple = count;
    i = 0;
    j = 0;
    while (i < count) {
        temp = (ir_data->data[i++] << 4) & 0xf0;
        temp |= (ir_data->data[i++]) & 0x0f;
        ir_data->data[j++] = temp;
        if (j > MAX_DATA) {
            j = MAX_DATA;
            return -1;
    ir_data->data_count = j;
    return j;
static int et4007_depress_sample(struct ir_remocon_data *ir_data)
    int i, j = 0;
    if (ir_data->index>MAX_SAMPLE_INDEX){
        ir_data->index = MAX_SAMPLE_INDEX;
        return -1;
    for (i = 0; i < ir_data->index; i++) {
        ir_data->zp_sample[j++] = (uint8_t)(ir_data->sample >> 8) & 0xff;
        ir_data->zp_sample[j++] = (uint8_t)ir_data->sample;
    ir_data->index = j;
    return j;
static void remote_timer_handle(unsigned long data)
    if (!busy_status) {
        mod_timer(&remote_timer,jiffies+msecs_to_jiffies(100));
        if (!ET4007_GET_BUSY_STATE()) {
            busy_status = 1;
            wake_up_interruptible(&remote_waitq);
void et4007_start(void)
    ET4007_SET_SDA_OUTPUT();
    ET4007_SET_SDA_HIGH();
    ET4007_SET_SCL_OUTPUT();
    ET4007_SET_SCL_HIGH();
    ET4007_SET_SDA_LOW();
    udelay(START_DELAY);
    ET4007_SET_SCL_LOW();
void et4007_stop(void)
    udelay(STOP_DELAY);
    udelay(STOP_DELAY);
    udelay(STOP_DELAY);
    udelay(STOP_DELAY);
    //ET4007_SET_SDA_INPUT();
    udelay(STOP_DELAY);
int et4007_i2c_write_byte(uint8_t dat)
    int err = 0;
    uint8_t i, dat_temp;
    dat_temp = dat;
    for (i = 0; i < 8; i++) {
        udelay(10);
        if (dat_temp & 0x80) {
        } else {
        udelay(CLK_DELAY);
        dat_temp <<= 1;
        udelay(CLK_DELAY);  // optional
        udelay(CLK_DELAY);
    udelay(CLK_DELAY);
    udelay(CLK_DELAY);
    //if(ET4007_GET_SDA_STATE())err=1;
    //else err=0;
    udelay(CLK_DELAY);
    return err;
uint8_t et4007_i2c_read_byte(void)
    uint8_t dat, i;
    dat = 0;
    for (i = 0; i != 8; i++) {
        udelay(CLK_DELAY);
        udelay(CLK_DELAY);
        dat <<= 1;
        if(ET4007_GET_SDA_STATE()) dat++;
        udelay(10);
    udelay(CLK_DELAY);
    udelay(CLK_DELAY);
    udelay(CLK_DELAY);
    return dat;
static int et4007_read_device_info(void)
    int ret = 0;
    int i;
    char buf[8] = {0};
    pr_info("%s: +n", __func__);
    et4007_start();
    /* write addr and cmd */
    et4007_i2c_write_byte(ET4007_ADDRESS);
    et4007_i2c_write_byte(ET4007_CONTROL_READ_VERSION);
    /* read device info */
    for (i = 0; i < 4; i++) {
        buf = et4007_i2c_read_byte();
    et4007_stop();
    pr_info("%s: dev_id: 0x%02x, 0x%02x, 0x%02x, 0x%02x n", __func__,
            buf[0], buf[1], buf[2], buf[3]);
    ret = buf[0]*0x1000000 + buf[1]*0x10000 + buf[2]*0x100 + buf[3];
    pr_info("%s: -n", __func__);
    return ret;
static long et4007_ioctl(struct file *filp, unsigned int cmd,unsigned long arg)
    int i;
    char buf[4];
    return 0;
static long et4007_ioctl_compat(struct file *filp, unsigned int cmd,unsigned long arg)
    int i;
    char buf[4];
    return 0;
static unsigned int et4007_poll( struct file *file,struct poll_table_struct *wait)
    unsigned int mask = 0;
    mod_timer(&remote_timer, jiffies + msecs_to_jiffies(40));
    poll_wait(file, &remote_waitq, wait);
    if (busy_status) {
        busy_status = 0;
        mask |= POLLIN | POLLRDNORM;
    return mask;
static ssize_t et4007_write(struct file *file, const char *buffer, size_t count, loff_t *ppos)
    char send_buff[256];
    int ret;
    int i;
    if (count == 0) {
        return -1;
    if(buffer[0]==ET4007_CONTROL_SEND_CODE_3) {
        if (count > 384) {
            printk("ET4007---count error---n");
            return -1;
        et4007_start();
        for (i = 0; i < count; i++) {
            et4007_i2c_write_byte(buffer);
        et4007_stop();
        return count;
    } else if (buffer[0] == ET4007_CONTROL_SEND_CODE_1) {
        if (count> 129) {
            count = 129;
            printk("ET4007---size error---n");
            return count;
        memset(send_buff,0x00,129);
        ret = copy_from_user(send_buff, buffer, count) ;
        if (ret) {
            printk("ET4007---copy error---n");
            return ret;
        et4007_start();
        for (i = 0; i < 129; i++) {
            et4007_i2c_write_byte(send_buff);
        et4007_stop();
        return count;
    } else {
        printk("ET4007---command  error---n");
        return -1;
    return count;
static ssize_t et4007_read(struct file *filp, char *buff,size_t count, loff_t *ppos)
    int i, err;
    int ET_crc;
    int ET_PartIndexCount;
    int ET_Sample;
    int ET_Index;
    int ET_Freq;
    int m = 0;
    int max = 0;
    char buf_ir_test[384];
    et4007_start();
    et4007_i2c_write_byte(ET4007_CONTROL_READ_CODE);
    ET_crc = et4007_i2c_read_byte();
    buf_ir_test[m++] = ET_crc;
    ET_PartIndexCount = et4007_i2c_read_byte();
    buf_ir_test[m++] = ET_PartIndexCount;
    ET_Sample = et4007_i2c_read_byte();
    buf_ir_test[m++] = ET_Sample;
    ET_Index = et4007_i2c_read_byte();
    buf_ir_test[m++] = ET_Index;
    ET_Freq = et4007_i2c_read_byte();
    buf_ir_test[m++] = ET_Freq;
    max = ET_PartIndexCount+ET_Sample+ET_Index;
    if (max > 380) {
        et4007_stop();
        return  -EFAULT;
    for (i = 0; i < max; i++) {
        buf_ir_test[m] = et4007_i2c_read_byte();
        m++;
    et4007_stop();
    if (m > sizeof(buf_ir_test)) {
        m = sizeof(buf_ir_test);
    err = copy_to_user((void *)buff, (const void *)(&buf_ir_test[0]), m);
    return err ? -EFAULT : m;
static int et4007_open(struct inode *inode, struct file *file)
    et4007_read_device_info();
    setup_timer(&remote_timer, remote_timer_handle, (unsigned long)"remote");
    return 0;
static int et4007_close(struct inode *inode, struct file *file)
    del_timer_sync(&remote_timer);
    return 0;
static struct file_operations et4007_fops = {
    .owner            = THIS_MODULE,
    .open            = et4007_open,
    .release        = et4007_close,
    .write          = et4007_write,
    .read            = et4007_read,
    .poll            = et4007_poll,
    .unlocked_ioctl    = et4007_ioctl,
#ifdef CONFIG_COMPAT
    .compat_ioctl   = et4007_ioctl_compat,
#endif
static void et4007_remocon_work(struct ir_remocon_data *ir_data)
    struct ir_remocon_data *data = ir_data;
    int sleep_timing;
    int emission_time;
    int i;
    //mutex_lock(&data->mutex);
    et4007_start();
    for (i = 0; i < ir_data->length; i++) {
        et4007_i2c_write_byte(ir_data->signal);
    et4007_stop();
    //mutex_unlock(&data->mutex);
    emission_time = ( (data->ir_sum) * (data->freq) * 4 / 5000);
    sleep_timing = emission_time -10;
    if (sleep_timing < 0) {
        sleep_timing = 10;
    data->freq = 0;
    data->ir_sum = 0;
static ssize_t et4007_ir_send_store(struct device *dev, struct device_attribute *attr,
        const char *buf, size_t size)
    unsigned int data;
    int err;
    int count = 0, i;
    ir_data->count = 0;
    ir_data->send_flag = 1;
    if (ir_data->count < 5) {
        printk("data->count < 5 error nr");
        return -1;
    err = et4007_compress_original_data(ir_data);
    if (err < 0) {
        printk("et4007_compress_original_data  error nr");
        return -1;
    et4007_remocon_work(ir_data);
    return size;
static ssize_t et4007_ir_send_show(struct device *dev, struct device_attribute *attr, char *buf)
    int i;
    int len = 0;
    char buf_read[8] = {0};
    return len;
static DEVICE_ATTR(ir_send, 0664, et4007_ir_send_show, et4007_ir_send_store);
static ssize_t et4007_ir_learn_store(struct device *dev, struct device_attribute *attr,
    unsigned int data;
    if (sscanf(buf++, "%u", &data) == 1) {
    return size;
static ssize_t et4007_ir_learn_show(struct device *dev, struct device_attribute *attr, char *buf)
    int crc, part_index_count, sample, index, freq;
    int i, m = 0, max = 0, len = 0;
    char buf_read[386] = {0};
    et4007_start();
    /* crc */
    buf_read[m++] = crc;
    /* part index count */
    part_index_count = et4007_i2c_read_byte();
    buf_read[m++] = part_index_count;
    /* sample */
    sample = et4007_i2c_read_byte();
    buf_read[m++] = sample;
    /* index */
    index = et4007_i2c_read_byte();
    buf_read[m++] = index;
    /* freq */
    freq = et4007_i2c_read_byte();
    buf_read[m++] = freq;
    pr_info("%s: part_index_count = %d, sample = %d, index = %dn", __func__,
            part_index_count, sample, index);
    max = part_index_count + sample + index;
    if (max > 380) {
        et4007_stop();
        sprintf(buf, "error");
        return len;
        buf_read[m] = et4007_i2c_read_byte();
        m++;
    et4007_stop();
    for (i = 0; i < m; i++) {
        if (i == 0) {
            len = sprintf(buf, "%d", buf_read);
        } else {
            len += sprintf(buf + len, ",%d", buf_read);
        //pr_info("%s: learn data[%d] = %dn", __func__, i, buf_read);
    pr_info("n");
    len += sprintf(buf + len, "n");
    return    len;
static DEVICE_ATTR(ir_learn, 0664, et4007_ir_learn_show, et4007_ir_learn_store);
static ssize_t et4007_ir_state_show(struct device *dev, struct device_attribute *attr, char *buf)
    int len = 0;
    if (ET4007_GET_BUSY_STATE()) {
        len = sprintf(buf + len, "%dn", 1);
    } else {
        len = sprintf(buf + len, "%dn", 0);
    return    len;
static DEVICE_ATTR(ir_state, 0444, et4007_ir_state_show, NULL);
static ssize_t et4007_ir_info_show(struct device *dev, struct device_attribute *attr, char *buf)
    int i, len = 0;
    len += sprintf(buf + len, "%d,", ir_data->send_flag);
    len += sprintf(buf + len, "%d,", ir_data->orig_freq);
    for (i = 0; i < ir_data->count; i++) {
        len += sprintf(buf + len, "%d,", ir_data->original);
    ir_data->send_flag = 0;
    return    len;
static DEVICE_ATTR(ir_info, 0444, et4007_ir_info_show, NULL);
static int et4007_parse_dt(struct device *dev)
    if (!dev || !dev->of_node || !ir_data)
        return -1;
    ir_data->clk_gpio = of_get_named_gpio_flags(dev->of_node, "etek,clk-gpio", 0, NULL);
    if (!gpio_is_valid(ir_data->clk_gpio)) {
        pr_err("%s: clk gpio is invalid !n ", __func__);
        return ir_data->clk_gpio;
    pr_info("%s: clk gpio = %dn", __func__, ir_data->clk_gpio);
    ir_data->sda_gpio = of_get_named_gpio_flags(dev->of_node, "etek,sda-gpio", 0, NULL);
    if (!gpio_is_valid(ir_data->sda_gpio)) {
        pr_err("%s: sda gpio is invalidn ", __func__);
        return ir_data->sda_gpio;
    pr_info("%s: sda gpio = %dn", __func__, ir_data->sda_gpio);
    ir_data->busy_gpio = of_get_named_gpio_flags(dev->of_node, "etek,busy-gpio", 0, NULL);
    if (!gpio_is_valid(ir_data->busy_gpio)) {
        pr_err("%s: busy gpio is invalidn ", __func__);
        return ir_data->busy_gpio;
    pr_info("%s: busy gpio = %dn", __func__, ir_data->busy_gpio);
    return 0;
static struct miscdevice et4007_misc_dev = {
    .minor = MISC_DYNAMIC_MINOR,
    .name = DEVICE_NAME,
    .fops = &et4007_fops,
static int et4007_probe(struct platform_device *pdev)
    struct device *ir_remocon_dev;
    int error;
#ifdef ET_POWERCONTROL
    ET4007_SET_POWER_HIGH();
    mdelay(1);
#endif
    ir_data = kzalloc(sizeof(struct ir_remocon_data), GFP_KERNEL);
    if (NULL == ir_data) {
        pr_err("%s: failed to kzalloc memory for ir_data !n", __func__);
        error = -ENOMEM;
        goto err_free_mem;
    error = et4007_parse_dt(&pdev->dev);
    if (error) {
        pr_err("%s: failed to parse dt !n", __func__);
        return error;
    error = gpio_request(ET4007_SCL_GPIO, DEVICE_NAME);
    if (error) {
        pr_err("%s: failed to request scl gpio (%d) !n", __func__, ET4007_SCL_GPIO);
        return error;
    error = gpio_request(ET4007_SDA_GPIO, DEVICE_NAME);
    if (error) {
        pr_err("%s: failed to request sda gpio (%d) !n", __func__, ET4007_SDA_GPIO);
        return error;
    error = gpio_request(ET4007_BUSY_GPIO, DEVICE_NAME);
    if (error) {
        pr_err("%s: failed to request busy gpio (%d) !n", __func__, ET4007_BUSY_GPIO);
        return error;
    et4007_class = class_create(THIS_MODULE, "etek");
    if (IS_ERR(et4007_class)) {
        pr_err("%s: failed to create class(etek)!n", __func__);
        return PTR_ERR(et4007_class);
    ir_remocon_dev = device_create(et4007_class, NULL, 0, ir_data, "sec_ir");
    if (IS_ERR(ir_remocon_dev))
        pr_err("%s: failed to create ir_remocon_dev devicen", __func__);
    if (device_create_file(ir_remocon_dev, &dev_attr_ir_send) < 0)
        pr_err("%s: failed to create device file(%s)!n", __func__,
                dev_attr_ir_send.attr.name);
    if (device_create_file(ir_remocon_dev, &dev_attr_ir_state) < 0)
                dev_attr_ir_state.attr.name);
    if (device_create_file(ir_remocon_dev, &dev_attr_ir_learn) < 0)
                dev_attr_ir_learn.attr.name);
    if (device_create_file(ir_remocon_dev, &dev_attr_ir_info) < 0)
                dev_attr_ir_info.attr.name);
    ET4007_SET_BUSY_INPUT();
    return error;
err_free_mem:
    ET4007_SET_POWER_LOW();
#endif
    kfree(ir_data);
    ir_data = NULL;
    return error;
static int et4007_remove(struct platform_device *pdev)
    if (et4007_class)
        device_destroy(et4007_class, 0);
    if (ir_data)
        kfree(ir_data);
    return 0;
static struct of_device_id et4007_match_table[] = {
    {.compatible = "etek,ir", },
static struct platform_driver et4007_driver = {
    .probe    = et4007_probe,
    .remove   = et4007_remove,
    // .suspend  = et4007_suspend,
    //  .resume   = et4007_resume,
    .driver   = {
        .of_match_table = et4007_match_table,
static int __init et4007_init(void)
    if(misc_register(&et4007_misc_dev)) {
        pr_err("%s: misc_register register failedn", __func__);
    return platform_driver_register(&et4007_driver);
static void __exit et4007_exit(void)
    misc_deregister(&et4007_misc_dev);
    platform_driver_unregister(&et4007_driver);
module_init(et4007_init);
module_exit(et4007_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("ETEK Inc.");
MODULE_DESCRIPTION("ETEK consumerir Driver");
我们是用gpio模拟的i2c,所以代码比较冗长,但是功能还是可以的。有兴趣的话可以自己动手试一下。
