Cypress技术william hill官网
孟薇
7年用户 219经验值
PSoC 5LP原型区鹰图有吗
大家好,
我正在做一个鹰画一个PCB,需要的尺寸和位置的引脚的发展领域的PSoC 5LP发展板。
我想知道是否有一张我可以使用的现有图画。我们的目标是将我的模式直接导入到PSoC鹰绘图中。
请告知。
非常恭敬,
作记号
以上来自于百度翻译
     以下为原文
  Hello all,
I am doing an Eagle drawing for a PCB and need the dimensions and location of the pins of the developmental area of the PSoC 5LP developmental board.
I was wondering if there was an existing drawing I could use.  The goal is to import my schematic directly into the PSoC Eagle drawing.
Please advise.
Very Respectfully,
Mark
回帖(3)
徐小婷
2018-9-26 16:50:15
您可以得到的AlelGro韵律兼容的PSoC 5LP开发板的示意性文件,可在这个链接:
HTTP://www. CyPress .COM/DICONTION/Debug -KITSBBOARDS/CY8CKIT-050-PSOC-5LP开发套件
HTTP://www. CyPress .COM/DICONTION/Deavest-KITSBBOARDS/CY8CKIT-059PSOC-5LP原型KIT-OLAND程序员
以上来自于百度翻译
     以下为原文
  you  can get the  Allegro Cadence compatible only  schematic files of PSoC 5LP developmental board which is available at this link:
http://www.cypress.com/documentation/development-kit***oards/cy8ckit-050-psoc-5lp-development-kit
http://www.cypress.com/documentation/development-kit***oards/cy8ckit-059-psoc-5lp-prototyping-kit-onboard-programmer-and
孟薇
2018-9-26 17:03:08
你好。
当我尝试打开文件时,我收到以下错误:
错误:
第1行,第1栏:预期的开始标记。
你能建议一下吗?
恭敬地,
作记号
以上来自于百度翻译
     以下为原文
  Hello.
When I try to open the file, I receive the following error:
Error:
line 1, column 1: Start tag expected.
Can you please advise?
Respectfully,
Mark
徐小婷
2018-9-26 17:19:47
引用: frank201 发表于 2018-9-26 18:03
你好。
当我尝试打开文件时,我收到以下错误:
错误:
您正在尝试打开文件.DSN在哪个工具?鹰不能打开.DSN文件
以上来自于百度翻译
     以下为原文
  you are trying to open file .dsn in which tool? Eagle can't open the .dsn files
