您所看到的是操作系统处理工作负载放置的方式。
操作系统的一个限制是,它只会将图形工作负载放在它看作主要GPU的位置,因此是第一个K1 GPU。
您看到的GPU是否以100%的速度运行?
您还应该知道,除非您正在运行RemoteFX,否则远程会话将无法看到GPU加速。
Citrix有一些实验性代码允许在GPU上循环使用DirectX工作负载,但这需要XenApp。
如果您可以选择支持直通(XenServer,vSphere或KVM)的虚拟机管理程序,那么您可以配置4个虚拟机,每个虚拟机都有一个GPU。
虽然Hyper-V不支持这一点,但它有一个替代解决方案,但微软不支持它用于RDSH
如果这些不是一个选项,你不能虚拟化,那么你是正确的,你需要一个大小合适的Quadro卡。
以上来自于谷歌翻译
以下为原文
What you're seeing is the way that the OS is handling the placement of the workloads. It's a limitation in the OS that it will only place the graphics workload on what it see's as the primary GPU, so the first of the K1 GPU's.
Is the GPU you're seeing load on running at 100%?
You should also be aware that unless you're running RemoteFX, the remote session will not see GPU acceleration.
Citrix have some experimental code for allowing round robin use of DirectX workloads across the GPU's, but that will require XenApp.
If you have the option of a hypervisor that supports passthrough (XenServer, vSphere or KVM) then you could configure 4 VM's each with one GPU. Hyper-V doesn't support this though, it has an alternate solution but Microsoft doesn't support it for RDSH
If these aren't an option and you can't virtualise then you're correct, you'll need a good sized Quadro card.
以上来自于谷歌翻译
以下为原文
