是德科技
h1654155275.5697
7年用户 615经验值
LabVIEW驱动程序是否可以来驱动N5234A
你好,我正在研究Keysight N5234A PNA的labview代码,我搜索了NI网站,但没有找到这个型号的驱动程序。
我有20G N5230A的LabVIEW驱动程序,也是PNA-L系列,我从NI网站下载了这个驱动程序。
我想知道我是否可以用它来驱动N5234A。
如果没有,我应该做什么修改,或者我应该怎么做才能从N5234A读取数据?
谢谢。
以上来自于谷歌翻译
     以下为原文
  Hello,
I'm working on the LabVIEW code for Keysight N5234A PNA, I searched NI website but found no drivers for this model.
I have the LabVIEW driver for the 20G N5230A, which is also PNA-L family, I downloaded this driver from NI website. I'm wondering if I can use it to drive N5234A.
If not, what modifications should I make, or what should I do to read data from N5234A?
Thanks.
Cantata
回帖(5)
陈建华
2018-9-27 15:48:52
所有返回到2000年引入的第一个PNA都使用相同的核心固件。
当然,在引入新功能时会添加新命令,但是为早期的E8358A编写的代码仍然可以在最新的PNA或PNA-X上工作(只有少数例外)。
您可能遇到的唯一问题是,如果司机首先进行* IDN?
查询并将型号与预期结果进行比较。
我知道有些司机可以选择忽略这种比较。
但除此之外,司机应该工作得很好。
我们的编程页面上列有一个驱动程序,但它的日期是2010年,也不包括N5234A。
http://na.support.keysight.com/pna/programming/
以上来自于谷歌翻译
     以下为原文
  All PNAs going back to the first one introduced in 2000 use the same core firmware.  Of course, new commands are added as new features are introduced, but code written for an early E8358A will still work on even the latest PNA or PNA-X (with only a few exceptions).
The only issue you could have is if the driver first does a *IDN? query and compares the model number to the what it expects.  I know some drivers have the option to ignore this comparison.  But except for this, the driver should work just fine.
We have a driver listed on our programming page, but it is dated in 2010 and will also not include the N5234A.
h1654155275.5697
2018-9-27 15:58:41
你好,谢谢你的回复。
我可以使用N5230A LabVIEW代码来驱动N5234A吗?
另外我发现N5230A代码与E8358A相同。编辑:cantata于2015年4月28日下午6:51
以上来自于谷歌翻译
     以下为原文
  Hi, Thanks for your reply.
Can I use N5230A LabVIEW code to drive N5234A? Also I found N5230A code is just the same as E8358A.
Edited by: cantata on Apr 28, 2015 6:51 PM
陈建华
2018-9-27 16:05:59
引用: jack_study 发表于 2018-9-27 17:34
你好,谢谢你的回复。
当然......所有这些都是PNA型号,并且都使用相同的基本核心固件。
以上来自于谷歌翻译
     以下为原文
  Sure...all those are PNA models and all use the same basic core firmware.
h1654155275.5697
2018-9-27 16:13:30
以上来自于谷歌翻译
HI,我尝试使用N5230A代码来控制N5234A,但PNA无法初始化,即使我跳过ID查询部分。
以上来自于谷歌翻译
     以下为原文
  HI, I tried to use N5230A code to control N5234A, but the PNA couldn't be initialized, even I skip the ID query part.
