大家好 - 可能是错误的地方,但我想我会提高它..
我试图通过以下设置验证H264客户端解码的使用:
- 在ESXi 6.5上运行的Windows 10虚拟机。
VM具有使用P6-4Q配置文件分配的GRID P6 GPU
- 瘦客户端是英特尔NUC的混合,但主要是奔腾(Gemini Lake)CPU(使用HD605 GPU)和带有集成HD620 GPU的i3 CPU(Kaby Lake)
- NUC运行Ubuntu 18.04作为本地安装的操作系统(4.15.0-20-通用)
- 安装的Horizon客户端是4.7.0 build 7395152
- Horizon Agent和Direct Connec
tion插件的版本为7.4
我的目标是确认我的客户端是否正在将H264解码卸载到NUC GPU。
我的英特尔代表向我保证,上面提到的GPU能够实现此功能,但我看到Horizon客户端的信息告诉我这可能不会发生,如vmware-mksxxx.log文件中所示:
- RemoteDisplay.allowClientH264 ='TRUE'
这是指Horizon Client GUI中H264解码的选项。
确认为在GUI中删除勾选时,该值变为'RemoteDisplay.allowClientH264 ='FALSE',没有进一步的H264 entriesRemoteDisplay.allowClientH264 ='FALSE
- VNC客户端:H264硬件解码不可用
其他人在使用Horizon和GRID验证或验证硬件客户端解码时遇到问题?
谢谢
以上来自于谷歌翻译
以下为原文
Hi all - could be the wrong spot for this but thought i would raise it anyway..
I am trying to validate the use of H264 client decode with the following setup:
- Windows 10 virtual machine running on ESXi 6.5. VM has a GRID P6 GPU assigned using a P6-4Q profile
- Thin clients are a mix of Intel NUC but primarily Pentium (Gemini Lake) CPU (using HD605 GPU) and an i3 CPU (Kaby Lake) with an integrated HD620 GPU
- NUCs run Ubuntu 18.04 as a locally installed OS (4.15.0-20-generic)
- Horizon client installed is 4.7.0 build 7395152
- Horizon Agent and Direct Connection plug-in are at version 7.4
I am aiming to confirm whether my client is offloading H264 decode to the NUC GPU. I am assured by our Intel rep that the GPU mentioned above are capable of this function however i see information the Horizon client which tells me that this may not be happening, as per here in the vmware-mks-xxxx.log file:
- RemoteDisplay.allowClientH264 = ‘TRUE’
This refers to the option for H264 decode in the Horizon Client GUI. Confirmed as when removing the tick in the GUI, the value becomes ‘RemoteDisplay.allowClientH264 = ‘FALSE’ with no further H264 entriesRemoteDisplay.allowClientH264 = ‘FALSE
- VNC Client: H264 hardware decoding unavailable
Anyone else have trouble validating or verifying hardware client decode using Horizon and GRID?
Thanks
