应用程序的微芯片库具有USB HID的样本代码。你可以从那里开始修改你的需要。还有一些实用工具隐藏了你可以使用但用VisualC++编写的示例代码。你可以试着把它们编译成库并在你的C项目中添加DLL引用。我认为它可能会起作用。对于一个新的设计,我不建议使用PIC18F2550,你可以使用PIC18FXXK50系列。
以上来自于百度翻译
以下为原文
Microchip Libraries for Applications has sample codes with USB HID. You can start from there and modify to suite your need.
There are also some Utilities HID sample codes you can use but written with Visual C++. You can try to compile them as libraries and add the DLL reference in your C# project I think it might work.
For a new design I wouldn't recommend using the PIC18F2550, you can use the PIC18FxxK50 series.
以上来自于百度翻译
以下为原文
