英伟达
李桂芳
7年用户 169经验值
VMware Horizon 6.1零客户端断开连接上的vGPU
刚刚开始推出几款支持vGPU的Horizo​​n 6.1桌面池,配备戴尔P25 PCoIP零客户端和双显示器。
许多用户现在报告频繁的会话断开连接,但它非常随机。
屏幕变黑几秒钟,然后显示一条消息,表明您已断开连接。
同样的错误似乎在vSphere 6发行说明(http://www.nvidia.com/download/driverResults.aspx/85390/en-us)上针对vGPU的最新NVIDIA驱动程序包中描述为已知问题#59。
这是您在不久的将来即将推出的解决方案,还是我们需要继续告诉我们的工程师和设计师只是处理它?
任何解决方法的帮助也会有所帮助。
谢谢。
以上来自于谷歌翻译
以下为原文
Just began rolling out several vGPU enabled Horizon 6.1 desktop pools with Dell P25 PCoIP zero clients and dual-displays. Many users are now reporting frequent session disconnects, but it is very random.  Screen goes black for a few seconds, then shows a message that you have been disconnected.  This same error seems to be described in the latest NVIDIA driver bundle for vGPU on vSphere 6 release notes (http://www.nvidia.com/download/driverResults.aspx/85390/en-us) as known issue #59. Is this a fix that you see coming soon in the real near future, or will we need to continue telling our engineers and designers to just deal with it?  Any help on a workaround would be helpful as well.  Thank you.
回帖(28)
谭齐慧
2018-9-30 11:10:30
结合VMware,我们相信我们现在已经确定了问题的原因,并且正在努力尽快发布更新。
我目前没有时间表,但它是高度优先的。
以上来自于谷歌翻译
以下为原文
In conjuction with VMware we believe we've now identified the cause of the issue and are working on releasing an update as soon as we can.
I don't have a timeline at present but it is high priority.
陈蓓萤
2018-9-30 11:21:55
嗨,我有同样的问题。
你有什么新闻,我如何解决它或新的驱动程序何时可用?
谢谢你的回答。
以上来自于谷歌翻译
以下为原文
Hi, I have the same issue. Do you have any news, how I can solve it or when the new driver will be available?
Thank you for an answer.
李晶
2018-9-30 11:30:52
昨天我们发布了一组新的passthrough驱动程序,如果你在Passthrough / vDGA中遇到它,应该可以解决这个问题。
vGPU驱动程序将很快推出,由于它是一个2部分包,它会经历一个延长的QA循环,这就是为什么需要更长的时间。
发布已关闭,请在下周左右观看驱动程序页面,一旦我知道vGPU包可用,我就会更新该主题。
以上来自于谷歌翻译
以下为原文
Yesterday we released a new set of passthrough drivers which should resolve this issue if your encountering it in Passthrough / vDGA.
The vGPU drivers will follow soon, due to being a 2 part package it goes through an extended QA cycle which is why it takes a little longer.
Release is close, watch the driver pages over the next week or so and as soon as I know the vGPU package is available I'll update the thread.
颜婷
2018-9-30 11:46:44
你知道我们在哪里可以得到那些直通司机吗?
以上来自于谷歌翻译
以下为原文
Do you know where we can get those passthrough drivers?
