STM32/STM8技术william hill官网
马丹丹
7年用户 186经验值
DA通道2输出正常,DA通道1输出不正常,懂的帮忙看一下
static void DAC_Config(void)
        GPIO_InitTypeDef GPIO_InitStructure;
        DAC_InitTypeDef  DAC_InitStructure;
  /* 使能GPIOA时钟 */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
        /* 使能DAC时钟 */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
  /* DAC的GPIO配置,模拟输入 */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_4|GPIO_Pin_5 ;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* 配置DAC 通道1 */
  DAC_InitStructure.DAC_Trigger = DAC_Trigger_Software;                                                //使用软件触发
  DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;        //不使用波形发生器
  DAC_InitStructure.DAC_Buffer_Switch = DAC_BufferSwitch_Disable;        //不使用DAC输出缓冲
  DAC_Init(DAC1,DAC_Channel_1,&DAC_InitStructure);
  /* 配置DAC 通道2 */
   DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_Triangle;
   DAC_Init(DAC1, DAC_Channel_2,&DAC_InitStructure);
  /* 使能通道1 由PA4输出 */
  DAC_Cmd(DAC1,DAC_Channel_1, ENABLE);
  /* 使能通道2 由PA5输出 */
  DAC_Cmd(DAC1,DAC_Channel_2, ENABLE);
void DAC_test(void)
        DAC_Config();                    //调用DAC初始化函数
        DAC_DualSoftwareTriggerCmd(DAC1,ENABLE);           //同时启用两个DAC通道触发器
        DAC_SetChannel2Data(DAC1,DAC_Align_12b_R,0xfff);       //设置通道1输出电压值大约为3.3V
        DAC_SoftwareTriggerCmd(DAC1,DAC_Channel_1,ENABLE);//使能DAC通道1
         DAC_SetChannel2Data(DAC1,DAC_Align_12b_R,0x555);//设置通道1输出电压值大约为1.1V
        DAC_SoftwareTriggerCmd(DAC1,DAC_Channel_2,ENABLE);//使能DAC通道2
int main(void)
DAC_test();
  while (1)
}//通道1输出最大的时候也只是0.6V,而且根本不按程序的值输出。
回帖(6)
任娟娟
2018-10-1 08:36:12
恭喜楼主已经解决了
马丹丹
2018-10-1 08:55:07
我太粗心了,DAC_SetChannel2Data(DAC1,DAC_Align_12b_R,0xfff);  把这句改成:DAC_SetChannel1Data(DAC1,DAC_Align_12b_R,0xfff); 就好了
高建明
2018-10-1 09:01:14
不懂帮顶
袁富存
2018-10-1 09:07:28
三思而后行啊
冬妮
2018-10-1 09:18:33
不懂帮顶
李淇淇
2018-10-1 09:36:53
多细心点就好了
