英伟达
李峰
7年用户 158经验值
vSphere 6中的黑色控制台屏幕
我正在遵循vSphere 6中的XD7.6部署指南。在我的黄金映像虚拟机中安装NVIDIA驱动程序后,控制台屏幕为黑色,唯一的解决方法是使用RDP。
我在本指南的“故障排除”部分中看到了此特定问题。
我确实将虚拟机中的显卡内存增加到9,32和128MB但是没有用。
我接下来可以尝试的任何想法?
以上来自于谷歌翻译
以下为原文
I am following the Deployment Guide for XD7.6 in vSphere 6.  Once I install the NVIDIA drivers in my gold image virtual machine, the console screen is black and the only workaround is using RDP.  I saw this specific issue mentioned in the Troubleshooting section of the guide.  I did increase the video card memory in the virtual machine to 9, 32 and 128MB but that didn't work.  Any ideas what I can try next?
回帖(2)
黄明谊
2018-10-10 16:31:35
嗨Alepore,
我正在咨询我们的GRID专家,希望我们能尽快回复您,并考虑在故障排除部分添加更多信息。
请告诉我们任何有效或无效的步骤!
对不起,我没有直截了当。
最好的祝愿,
雷切尔
以上来自于谷歌翻译
以下为原文
Hi Alepore,
I'm checking with our GRID experts and hope we can get back to you soon and also look at adding more infor to the troubleshooting section. Do let us know any steps that work or don't for you too! I'm sorry it hasn't been straight forward.
Best wishes,
Rachel
周玲玲
2018-10-10 16:50:41
你好alepore,
这是使用vSphere的当前设计,而在XenSever中,您仍然可以通过XenCenter连接到控制台。
我通常要么安装了VNC,要么在NVIDIA驱动程序之前安装VDA。
在NVIDIA驱动程序之前安装VDA会要求您运行“MontereyEnable.exe -enable”。
如果这对您有用,请告诉我。
谢谢,
埃里克
NVIDIA GRID性能架构师
以上来自于谷歌翻译
以下为原文
Hello alepore,
this is the current design with vSphere whereas in XenSever you would still be able to connect to the console via XenCenter. I usually either have VNC installed or install the VDA before the NVIDIA driver. Installing the VDA before the NVIDIA driver will require you to run the "MontereyEnable.exe –enable" though.
Let me know if this works for you.
Thanks,
Erik
NVIDIA GRID Performance Architect
