vGPU使用中介(半虚拟化)驱动程序,该驱动程序需要在来宾和主机之间使用特定版本的NVidia专有协议(VGX)。
您需要兼容的VGX版本和支持VGX协议的增强驱动程序。
NVidia仅支持在GRID包中发布的组合(例如,对于GRID 5.2 - 384.111主机驱动程序和386.09 win guest驱动程序),但有时它也适用于具有兼容VGX协议的其他win客户驱动程序(由于“统一驱动程序”)但仅在
相同的“分支发布”行(参见:http://www.nvidia.com/object/quadro-branch-history-table.html)。
GRID 6.0几天前发布,带有390.42主机驱动程序和391.03 win客户驱动程序的驱动程序(请参阅https://docs.nvidia.com/grid/index.html)。
您应该升级到GRID 6.0。
以上来自于谷歌翻译
以下为原文
The vGPU uses mediated (paravirtualized) driver that needs specific version of NVidia proprietary protocol (VGX) between guest and host. You need the compatible VGX version and enhanced drivers with VGX protocol support. NVidia supports only combination that is released in GRID package (eg. for GRID 5.2 - 384.111 host driver and 386.09 win guest driver) but sometimes it works also other win guest driver with compatible VGX protocol (due to "unified driver") but only in the same "branch release" line (see: http://www.nvidia.com/object/quadro-branch-history-table.html). GRID 6.0 was released few days ago with driver with 390.42 host driver and 391.03 win guest driver (see https://docs.nvidia.com/grid/index.html). You should
upgrade to GRID 6.0.
您应该升级到GRID 6.0。
以上来自于谷歌翻译
以下为原文
