约翰,
我不是当前的ESXi用户,但据我所知,限制是基于底层虚拟机管理程序无法支持32位以上的XenServer版本的内存映射(因此在XenServer 6.5之前)。
如果ESXi基于64位操作系统,除非另有说明,否则您应该可以使用> 4 GB内存映射。
如果不是,则需要保持低于4 GB的边界。
您是否查看了NVIDIA文档以了解其安装设置建议是什么?
它是否表明ESXi不支持更高内存映射设置?
你必须拥有相当数量的设备才能触发甚至需要更高的内存映射 - 至少我从未在XenServer 6.2(32位)中看到这一点。
最重要的是,作为lomg工作并且稳定,应该没问题,但VMware和NVIDIA应该有特定的文档说明设置应该是什么。
如果仍有问题,您可能需要打开支持案例。
以上来自于谷歌翻译
以下为原文
John,
I'm not a current ESXi user, but as I understand it, the limitation was based on the underlying hypervisor not being able to support memory mapping above 4 GB for the XenServer versions that were 32-bit (so prior to XenServer 6.5). If ESXi is based on a 64-bit OS, you should be fine with the >4 GB memory mapping unless stated otehrwise. If not, you need to stay below the 4 GB boundary. Did you check the NVIDIA documentation to see what its installation setting recommendations are? WHere does it state that ESXi doesn't support the higher memory mapping setting? You must have a fair number of devices in there to trigger even needing the higher memory mapping -- I never saw this with XenServer 6.2 (32-bit), at least.
The bottom line is that as lomg as it works and is stable ot should be OK, but there should be specific documentation from both VMware and NVIDIA that state what the settings should be. If there is still an issue, you might need to open a support case.
约翰,
如果仍有问题,您可能需要打开支持案例。
以上来自于谷歌翻译
以下为原文
John,
