我相信最后一个微芯片TCP/IP协议栈是用C18编译器运行的,没有新版本支持XC8编译器,但是可以考虑MCC使用的微芯片TCP/IP Lite堆栈,它支持Enx24J600。PIC18F56K42由最新的MCC版本支持,所以应该如果TCP/IP堆栈特征包含在TTCP/IP Lite堆栈中。
以上来自于百度翻译
以下为原文
I believe the last microchip TCP/IP stack was released to run with C18 compiler, there is no new version supporting XC8 compiler, but you can consider
Microchip TCP/IP Lite Stack that you can use with MCC and it support ENCx24J600.
The PIC18F56K42 is supported by the latest MCC version, so it should work if the TCP/IP STACK features you want to implement are included in the TCP/IP Lite stack .
以上来自于百度翻译
以下为原文
