Microchip
刘东
7年用户 165经验值
程序员去模式验证?
我有一个部分是半编程,但程序员去指示它通过。程序员编程模式进行验证后,编程?(也许在设置代码保护之前?)我找不到任何地方记录的序列。谢谢!
以上来自于百度翻译
      以下为原文
    I have a part that was about half programmed but programmer to go indicated that it passed.
Does programmer to go mode do a verify after programming? (Maybe before setting code protect?) I couldn't find the sequence documented anywhere.
Thanks!
回帖(2)
傅双育
2018-10-10 15:17:19
是的,它应该在设置配置位之前进行验证。您使用的是MPLAX的哪个设备和哪个版本?
以上来自于百度翻译
      以下为原文
    Yes, it should do a verify before setting the config bits.
Which device and which version of MPLAB X are you using?
阎慧
2018-10-10 15:26:59
它是APIC16F1704T-I/mL。PK3程序员要在一月重新设置MPLAB IPE的当前版本。从那时起,它就被用于ON,而半编程只发生一次。我知道PK3不是一个“生产程序员”。这可能足以关掉这篇文章本身。(程序员要走的模式真是太方便了!)我希望PK4可能成为一个更好的长期解决方案,一旦它变得可用。
以上来自于百度翻译
      以下为原文
    It's a PIC16F1704T-I/ML. PK3 programmer to go was set up back in January with the current version of MPLAB IPE at the time. It has been used off an on since then and the half-programming is known to have happened only once.
I get that PK3 is not a "production programmer". That may be enough to close out this post in and of itself. (Programmer to go mode is just so darned handy!)
I'm hoping that PK4 may be a better long term solution once it becomes available.
