CPU需要特定的速度在运行Flash操作基础的EEPROM仿真,和需要的时间明显与当前运行。CPU保持运行,但在运行时阻止/轮询。
这取决于你有什么样的芯片,有一些额外的功能,可能会改变上面的声明(PSoC具有更多的功能和行为)。 只要你有足够的电压,并且不介意CPU撞为24MHz(IIRC)写flash的时候,那听起来像模拟EEPROM写将异步运行的CPU?(为了清晰起见,它可能会在API中阻塞) 以上来自于百度翻译 以下为原文 The CPU requires a specific speed when running the flash operations underlying the EEPROM Emulation, and take a noticeable amount of time and current to run. The CPU keeps running, but blocks/polls while operating. Depending on what kind of chip you have, there is some additional functionality that may change the statement above (the PSoC 6 has more functionality and behavior). As long as you have enough voltage, and don't mind the CPU bumping to 24MHz (IIRC) when writing flash, then it sounds like the EEPROM emulation writes will run asynchronously to the CPU? (It might block in the API for clarity's sake) |
对于EMEEPROM组件,存在阻塞写入和非阻塞写入。副作用可以是(依赖于设备的)时钟频率在写入期间可能发生变化。详情请参阅系统参考指南(从创建者帮助)。
鲍勃 以上来自于百度翻译 以下为原文 There are blocking writes and non-blocking writes for em_eeprom component. A side effect can be (device dependent) that the clock frequency might get changed during the write. For details see in System Reference Guide (from Creator help). Bob |
756个成员聚集在这个小组
加入小组2125 浏览 1 评论
1867 浏览 1 评论
3683 浏览 1 评论
1803 浏览 6 评论
1550 浏览 1 评论
613浏览 2评论
456浏览 2评论
451浏览 2评论
403浏览 2评论
1089浏览 2评论
GMT+8, 2025-1-15 03:15 , Processed in 0.681116 second(s), Total 46, Slave 40 queries .
