英特尔
孙乙鑫
7年用户 239经验值
受磁铁影响的RealSense D415/D435?
你好,
我需要在难以维修的区域安装一些RealSense摄像头,并考虑使用磁铁进行安装。
相机背面或底部附近的强磁钕磁铁是否会影响其功能?
谢谢,
以上来自于谷歌翻译
以下为原文
Hello,
I need to mount a few RealSense cameras in a hard to service area and am considering using magnets for mounting. Would a strong neodymium magnet near the back or bottom of the camera have any affect on it's function?
thanks,
Dan
回帖(1)
卿洁
2018-10-11 17:12:52
虽然我不太了解400系列相机上的磁铁,但较老的R200外壳USB型号 - 也是立体声相机 - 后部有一块坚固的磁铁,由磁板覆盖。
目的是在移除磁板时将相机连接到诸如监视器之类的表面上。
磁铁对R200的操作没有任何不良影响。
编辑:我检查了400系列的数据表文件,根本没有提到磁铁。
如果这是一个潜在的问题,它可能会列在文档中。
R200仍然以英特尔在线点击商店的折扣价格提供,因为它是一种退役型号并且库存正在被清除。
由于它的老化,它的功能比400系列要小得多,但对于简单的监控应用来说可能就足够了。
英特尔®实感™开发套件(R200),VF0830
以上来自于谷歌翻译
以下为原文
Whilst I do not know about magnets on the 400 Series cameras specifically, the older R200 cased USB model - which is also a stereo camera - has a strong magnet on its rear, covered by a magnetic plate.  The purpose is so the camera can be attached to surfaces such as monitors when the magnetic plate is removed.  The magnet has no ill effects on the R200's operation.
Edit: I checked the 400 Series' data sheet document, and there is no mention of magnets at all.  It would likely be listed in the document if it was a potential problem.
The R200 is still available at a discount price in Intel's online Click store, as it is a retired model and the stock is being cleared.  It has greatly lesser capabilities than the 400 Series due to its age, but may be sufficient for simple monitoring applications.
Intel® RealSense™ Developer Kit (R200), VF0830
