Michael Fortneris在上述回应中。到目前为止,没有从应用程序中访问I2S接口的驱动程序。
I2S接口用于在使用A2DP等音频配置文件的同时对音频样本进行路由,所选择的数据路径为I2S。
换句话说,开发人员不能从应用程序访问I2S块,它只能用于传输A2DP配置文件的音频样本,而固件将在使用时负责配置接口。
以上来自于百度翻译
以下为原文
Michael Fortneris right in the above response. As of now, there are no drivers to access the I2S interface from application.
The I2S interface is used for routing audio samples while using audio profiles such as the A2DP and the selected data path is I2S. The I2S block is configured automatically by the Bluetooth firmware.
In other words, developers cannot access the I2S block from application, it can be only be used to transfer audio samples for A2DP profile and the firmware will take care of configuring the interface when used.
以上来自于百度翻译
以下为原文
