嗨Taisa,
感谢您与我们联系。
请按照下面提到的步骤来简化您的安装:
1.如果您已经创建了conda环境并将其激活,则可以使用conda install进行直接安装。
conda install scikit-learnconda install xlrd(假设你所需的包是xlrd而不是xlrs)
有关使用conda环境的信息,请参阅以下链接:https://communities.intel.com/docs/DOC-112294
2.如果要在没有conda环境的情况下直接安装软件包,建议使用--user开关将pip安装到本地或主目录中
pip install scikit-learn --userpip install xlrd --user
如果有帮助,请告诉我们。
如果您遇到任何问题,请退回。
谢谢&
问候,Sandhiya
以上来自于谷歌翻译
以下为原文
Hi Taisa,
Thanks for reaching out to us.
Kindly follow the below mentioned steps to ease your installations:
1. If you have already created a conda environment and activated it, you can do a direct installation using
conda install.
conda install xlrd (Assuming your required package is xlrd and not xlrs)
For information regarding using conda environments, refer the following link :
2. If you want to install the package directly without a conda environment, it is recommended to use the --user switch for pip to install in your local or home directory
Please do let us know if it helps. Kindly get back in case you face any issues.
Thanks & Regards,
Sandhiya
嗨Taisa,
感谢您与我们联系。
请按照下面提到的步骤来简化您的安装:
如果有帮助,请告诉我们。
如果您遇到任何问题,请退回。
谢谢&
问候,Sandhiya
以上来自于谷歌翻译
以下为原文
Hi Taisa,
conda install.
Thanks & Regards,
Sandhiya
