您好DarkerSavant,感谢您在英特尔®社区发帖。如果我理解您,您目前使用英特尔®Optane™内存加速驱动器,并且您希望将此驱动器镜像到另一个用于备份目的,
如果是这样,我必须告诉你,这个配置还没有经过测试或验证,所以我不能告诉你它会起作用。
英特尔®Optane™内存与驱动器配对后,可存储系统文件以实现加速。
这就是为什么如果从系统中删除其中一个驱动器或模块而不首先从应用程序中解除它们,驱动器或模块将无法工作。以下这一行,当您镜像连接驱动器时,它可能与所有系统文件镜像,
所以镜像驱动器可能没用;
或者它可能会有用,但它需要英特尔®Optane™内存才能工作。
无论如何,我无法告诉你究竟发生了什么,因为这个场景没有经过测试,因此不受支持。我建议您首先从应用程序中禁用Intel®Optane™内存。
然后,一旦驱动器解除关联,您就可以镜像它并备份信息。
最后,您可以再次重新启用该模块并继续照常工作。
我建议您采用这种方式,因为英特尔®Optane™内存可能会像其他任何驱动器一样出现故障,因此最好在没有英特尔®Optane™内存的情况下备份数据,这样您就不会遇到问题或意外结果
从备份驱动器访问数据。我希望我已经回答了您的问题。
如果我误解了你想做什么,请告诉我。祝你有个美好的一天.Regards,Diego V.
以上来自于谷歌翻译
以下为原文
Hi DarkerSavant,
Thank you for posting in the Intel® communities.
If I understood you well, you currently have a drive that is being accelerated with the Intel® Optane™ Memory, and you would like to mirror this drive into another for backup purposes, correct?
If so, I have to tell you that this configuration has not been tested nor validated, therefore I cannot tell you that it’ll work. The Intel® Optane™ Memory, when it’s paired with a drive, it stores system files to make the acceleration possible. That’s why the drive or the module won’t work if you remove one of them from the system without deconcatenating them first from the application.
Following this line, when you mirror the concatenated drive, it may be mirrored with not all the system files, so the mirrored drive may be useless; or maybe it will be useful but it will require the Intel® Optane™ Memory to work. Anyhow, I cannot tell you what happens exactly as this scenario is not tested and therefore not supported.
My recommendation for you is to disable the Intel® Optane™ Memory first from the application. Then, once the drive has been deconcatenated, you can mirror it and backup the information. Finally, you can re-enable the module again and continue working as usual. I recommend you this way because the Intel® Optane™ Memory may fail as any other drive, so it should be preferable to have a backup of the data without the Intel® Optane™ Memory, so you won’t have issues or unexpected results when accessing the data from the backup drive.
I hope I have answered your concern. If I misunderstood what you want to do, please let me know.
Have a nice day.
Regards,
Diego V.
所以镜像驱动器可能没用;
以上来自于谷歌翻译
以下为原文
Hi DarkerSavant,
Have a nice day.
Regards,
Diego V.
