是德科技
凌流浪
8年用户 1024经验值
擅长:可编程逻辑 电源/新能源
86142B触发延迟
嗨,我正在尝试使用OSA上的外部触发功能测量30 mS脉冲。
在我开始30mS激光脉冲之前,我似乎需要在触发OSA后给出30 mS的延迟。
这听起来是对的还是我错过了什么?
谢谢,贾斯汀
以上来自于谷歌翻译
     以下为原文
  Hi,
I am trying to measure a 30 mS pulse using the external triggering capability on the OSA.  It seems like I need to give a 30 mS delay after triggering the OSA before I start my 30mS Laser pulse.  Does this sound right or am I just missing something?
Thanks,
Justin
回帖(1)
贾大林
2018-10-19 11:48:19
您好贾斯汀,我认为如果您触发波长扫描,〜30ms延迟可能是正常的。
最小扫描时间似乎约为75ms,即使是非常短的范围,因此这可能是机械光栅运动的加速时间所决定的。
您可以通过将跨度设置为零来检查,中心波长设置在您想要的位置。
然后“扫描”将显示信号在恒定波长下的时间依赖性,并且不会产生机械延迟。
当然,如果这是你的目标,这并不能很容易地为你提供频谱。
然后在触发后使用延迟可能是您最好的方法。
麦克风
以上来自于谷歌翻译
     以下为原文
  Hello Justin,
I think the ~30ms delay may be normal if you are triggering a wavelength sweep. The minimum sweep time seems to be about 75ms, even for very short ranges, so this is probably dominated by acceleration times for the mechanical grating movements.
You could check that by setting the span to zero, with the center wavelength set where you want it. Then the "sweep" will show the time dependence of the signal at constant wavelength and won't have the mechanical delay. Of course that doesn't give you the spectrum very easily if that is your goal. Then using the delay after the trigger is probably your best approach.
Mike
