您好,我再次,我也刚刚购买ZENA无线适配器,2.4GHz,MRF24J40,零件号AC182015-1我也下载并安装了无线开发工作室V4.2。这些文件默认安装在:C:程序文件(x86) Microchip 无线开发工作室根据ZeNeZead指南(PG 16),当适配器插入Windows应立即提示硬件时,即USB驱动器、安装。也就是说,它应该打开一个“新发现的硬件向导”窗口,但是这不会发生!控制面板&设备和打印机显示了ZENA适配器,但是说:“这个设备的驱动程序没有安装(代码28)”你能告诉我如何安装驱动程序吗?我的电脑在Windows 10上。非常感谢,肯。
以上来自于百度翻译 以下为原文 Hello, me again, I have also just purchased the ZENA Wireless Adapter, 2.4GHz, MRF24J40, Part number AC182015-1 I have also downloaded and installed Wireless Development Studio v4.2. The files have been installed by default at: C:Program Files (x86)MicrochipWireless Development Studio According to the Zena Guide (pg 16), when the Adapter is plugged in Windows should prompt for hardware, ie USB driver, installation. That is, it should open a "New found Hardware Wizard" window. But this does not happen! The Control Panel > Devices and Printers shows the ZENA Adapter, but says: "Drivers for this device are not installed (code 28)" Can you advise me on how to install the drivers? My PC is on Windows10. Many thanks, Ken. |
8个回答
驱动程序没有签名,所以它不会在Windows 10上安装而不会跳过箍。它将安装在一个旧版本的Windows,如果你有它。这是我所做的使它安装:在一个管理员shell,do:Ro/r/o/f/t 00点击“OK”按钮系统将重新启动到一个“选择一个选项”屏幕选择“故障排除”选择“高级选项”选择“Windows启动设置”点击“重新启动”按钮系统将重新启动到“高级”。启动选项“屏幕选择”禁用驱动程序签名强制“当安装驱动程序时,单击父目录,而不是AMD64目录:& LT;PATH & GT;无线开发工作室驱动程序和INFZENA无线适配器2.4 GHz MRF24J40,我发现一些主要的Windows更新将unun安装驱动程序,迫使你再次经历那些废话。
以上来自于百度翻译 以下为原文 The driver isn't signed, so it won't install on Windows 10 without jumping through hoops. It will install on an older version of Windows if you have it. This is what I did to get it to install:
directory: And I've found that some of the major Windows updates will uninstall the driver, forcing you to go through all that nonsense again. |
谢谢您的快速回复。我遵照了您的指示,并禁用了驱动程序签名的执行。但没有效果;在插入Zena时,没有新发现的硬件向导出现,其他任何东西都邀请我安装驱动程序。一切似乎都与从前一样。
以上来自于百度翻译 以下为原文 Thanks for quick reply. I have followed your instructions, and have Disabled Driver Signature Enforcement. But to no avail; no New found Hardware Wizard appears when I insert the Zena, nor anything else inviting me to install drivers. Everything seems to be same as before. |
您必须用“更新驱动程序”选项在设备管理器中手动安装驱动程序。
以上来自于百度翻译 以下为原文 You have to manually install the driver in device manager with the "Update Driver" option. |
啊,是的,我知道这一点。但是属性面板说:“这个设备没有兼容的驱动程序”,更新驱动程序按钮没有启用,或者至少当我点击它时没有发生。
以上来自于百度翻译 以下为原文 Ah, yes, I am aware of that. But the properties panel says: "There are no compatible drivers for this device", and the Update driver button is not enabled, or at least nothing happens when I click on it. |
你后来重启了吗?我认为上面的程序只有在下一次重新启动之前才有效。
以上来自于百度翻译 以下为原文 Did you subsequently reboot? I think the procedure above is only valid until the next reboot. |
程序本身涉及重新启动,但在此之后,我没有进行后续重启。
以上来自于百度翻译 以下为原文 The procedure itself involved a reboot, but after that I have not had a subsequent reboot. |
您好,经过许多时间和努力,我已经安装了驱动程序。这里是完整的程序;它包含了来自以上回复的信息,加上来自其他william hill官网
帖子的信息。我希望把它全部放在一个帖子回复中会帮助其他人。首先,如何安装ZENA无线适配器的驱动程序,您必须安装无线开发系统,因为该工具具有所需的驱动程序。它将驱动文件放置在:C:程序文件(x86) Microchip 无线开发Studio 驱动器和INFZENA无线适配器2.4 GHz MRF24J40\文件名是:ZENA适配器2.4GHz MRF24J40。驱动程序没有签名,所以它不会在Windows 10上安装而不会跳过箍环。如果你有它,它将安装在旧版本的Windows上。这是如何使它安装在Windows 10上:在管理员命令shell中,输入:关机/ r/o/f/t 00点击“OK”按钮系统W。选择“高级选项”选择“Windows启动设置”点击“重新启动”按钮系统将重新启动到“高级启动选项”屏幕选择“禁用驱动程序签名强制”PC现在将重新启动。打开设备管理器,这是在开始和GT计算机管理下找到的,然后选择设备管理器。插入ZeNA适配器,它应该出现在其他设备上。双击它。选择更新驱动程序,然后选择“浏览我的计算机驱动软件”浏览到:C:程序文件(x86)微芯片无线开发工作室驱动程序和INFZENA无线适配器2.4 GHz MRF24J40 (不选择AMD64或I38 6文件夹)和OK。将出现警告;无论如何选择安装。设备状态现在应该说:设备正在正常工作。一些主要的Windows更新将卸载驱动程序,迫使你再次经历这些废话。
以上来自于百度翻译 以下为原文 Hello, After much time and effort I have managed to install the drivers. Here is the complete procedure; it incorporates info from replies above, plus info from other forum posts. I hope that putting it all in one post reply will help others. HOW TO INSTALL THE DRIVERS FOR ZENA WIRELESS ADAPTER First, you must install the Wireless Development System, as that tool has the required drivers. It places the driver file at: C:Program Files (x86)MicrochipWireless Development StudioDriver and InfZENA Wireless Adapter 2.4 GHz MRF24J40 and the filename is: ZENA Adapter 2.4GHz MRF24J40 .inf Second, the driver isn't signed, so it won't install on Windows 10 without jumping through hoops. It will install on an older version of Windows if you have it. This is what to do to get it to install on Windows 10: In an administrator command shell, enter: shutdown /r /o /f /t 00 Click the "OK" button System will restart to a "Choose an option" screen Select "Troubleshoot" Select "Advanced options" Select "Windows Startup Settings" Click "Restart" button System will restart to "Advanced Boot Options" screen Select "Disable Driver Signature Enforcement" PC will now restart. Open Device Manager, this is found under Start -> Computer Management, then select Device Manager. Plug in the ZENA adapter, it should appear under Other Devices. Double click on it. Select Update Drivers, then select "Browse my computer for driver software" Browse to: C:Program Files (x86)MicrochipWireless Development StudioDriver and InfZENA Wireless Adapter 2.4 GHz MRF24J40 (Do not select the amd64 or i386 folders) and OK. A warning will appear; select Install anyway. Device Status should now say: Device is working properly. Some of the major Windows updates will uninstall the driver, forcing you to go through all that nonsense again. |
谢谢各位先生。听从你的指示,我嗅了嗅。
以上来自于百度翻译 以下为原文 Thank you gentlemen. Followed your directions to the letter and I am sniffing away. |
5277 浏览 9 评论
2053 浏览 8 评论
1966 浏览 10 评论
3228 浏览 3 评论
2275 浏览 5 评论
812浏览 1评论
706浏览 1评论
644浏览 1评论
702浏览 0评论
600浏览 0评论
GMT+8, 2025-1-9 00:56 , Processed in 1.220729 second(s), Total 88, Slave 72 queries .
